Is it okay to run different size wheels in the rear???
Old Mar 9, 2013 | 09:57 PM
(ZzzzzZ)'s Avatar
(ZzzzzZ)
Default Is it okay to run different size wheels in the rear???
Hey guys,
So im currently running 10.5 width with +12 offset wheels in the rear. one of the wheels seems to be bent, since my tire stopped holding air and there are no holes or nails in it. I have an extra wheel lying around, but its an 11 inch width wheel with +12 offset. Is it okay if I throw that on? The tire sizes would stay the same, just one of the wheels would be .5 inches bigger. Is that ok??
Old Mar 10, 2013 | 04:00 AM
JCITY's Avatar
JCITY
IMO,you will not notice the difference.
You mean you have the same exact wheel(make/style)but its a .5" wider?
What other stuff do you have in your garage?
Old Mar 10, 2013 | 05:18 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Won't matter.
Old Mar 10, 2013 | 06:18 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
It has been done since the beginning of non-full size spare tires.
Old Mar 10, 2013 | 09:12 AM
(ZzzzzZ)'s Avatar
(ZzzzzZ)
Yes I have varrstoens and for some reason one day I was driving off and heard the tire flapping but no holes or anything wrong with the tire. I have an extra Varrstoen wheel, same offset and style, just in 11 inch width as opposed to 10.5. Wondering if that would throw anything off since the other side is a 10.5
Old Mar 10, 2013 | 09:21 AM
terrasmak's Avatar
You will be fine, but it will cause extra wear and tear on an LSD. Couple days around town, no big deal.
Old Mar 10, 2013 | 11:38 AM
(ZzzzzZ)'s Avatar
(ZzzzzZ)
^^Couple days??? Oh, so I should eventually get a 10.5 inch wheel? My z is a touring, so I have lsd right? Sorry for noob question...
Old Mar 10, 2013 | 03:19 PM
2004Black350z
Exhaust Whore
So your asking what could happen if this was a permanent replacement?
If so I'm going to say NO. Very dumb
Old Mar 10, 2013 | 03:24 PM
(ZzzzzZ)'s Avatar
(ZzzzzZ)
Thanks for the answer. Here is another serious question. How is running a 11 inch wheel with +12 offset different from running a 10.5 inch wheel with +12 offset with a 13mm spacer? They would technically be the same size after the spacer. Is my logic wrong??
Old Mar 10, 2013 | 03:26 PM
(ZzzzzZ)'s Avatar
(ZzzzzZ)
Or, hypothetically, what if i was running a 10.5 inch wheel with +12 offset, but the other side is a 10.5 with +0 offset. Would that be dumb/bad too? I'm not trying to ask stupid questions, if it is im sorry, just trying to understand. Thanks
Old Mar 10, 2013 | 03:43 PM
KingBaby's Avatar
KingBaby
Hardest Setting
if you are just trying to get around/dd/make it to payday or the sale of other wheels or something like that then it's fine...
from a performance aspect lots of ramifications
Old Mar 10, 2013 | 04:11 PM
terrasmak's Avatar
Offset is not really the important part. Equal tires on different width wheels will have a slightly different OD
Old Mar 11, 2013 | 01:06 PM
Waiz's Avatar
Waiz
Temporary yes, like everyone else has said
Old Mar 11, 2013 | 04:27 PM
Spike100's Avatar
Spike100
You should not run different rear wheel widths for anything more than a couple of days or a couple of hundred miles.
Every rotation places unusual stresses on various suspension components, and the rear tires won't sit exactly the same causing an dis-advantageous wear pattern.
--Spike
Old Mar 11, 2013 | 05:22 PM
angelo350z's Avatar
angelo350z
One rear tire would be more stretched than the other, but the contact patch will be the same considering the offsets and tire sizes are the same. Is the difference in weight and rotational mass that will upset your car's balance. Make both sides identical as soon as you can. In the meantime, you can add spacers to even out the poke.
bcoffee20
Nov 19, 2015 06:39 PM
abarclay
South East Marketplace
Sep 21, 2015 01:55 PM
EnjukuRacing
Coupons
Sep 9, 2015 08:13 AM
