Enkei Kojin - Will these work?
Old Jul 1, 2013 | 08:28 AM
Tearik's Avatar
Tearik
Default Enkei Kojin - Will these work?
Ok, I've been doing some research, and even made another thread.
I've pretty much settled on the Enkei Kojin wheels.
http://www.enkei.com/kojin.shtml#
I have a 2003 Touring, so my current wheels sizes are 18x8 w/ a 30mm offset all the way around, and I have 245/45/18 and 225/45/18 tires.
I'm wanting to stick to an 18" wheel, and I'm looking at a 9.5" width.
For that the Kojins have an 18x9.5 in 5x114.3 with a 15mm offset and a 30mm offset.
I want the new set up to look a bit more aggressive than the stock look, so I was thinking the 15mm offset for the kojins. With 275/40/18 and 255/40/18 tires. Thats a .2% difference in circumference than stock, so I know that VDC will be appeased; however, I just want to make sure that I'm understanding everything right.
The 15mm offset will make the wheels stick out a bit farther than stock?
And will the 15mm offset fit in the Z w/o a fender roll or will I need to have them rolled?
If that 15mm isn't going to give me at least a solid flush look, then I'll need to look into spacers I guess, but I'll await feedback for now.
Old Jul 1, 2013 | 08:40 AM
Bmurray350z's Avatar
Bmurray350z
9.5 +15 will be flush in the front, but you will need 10-15mm spacer for the rear to make it sit flush.
Old Jul 1, 2013 | 08:49 AM
Tearik's Avatar
Tearik
That doesn't seem too bad. guess its time to learn about wheels spacers!
Also: Sitting flush in the rear, will or will not make me need to roll my fenders?
Old Jul 1, 2013 | 08:52 AM
Bmurray350z
well yes, being flush with the fender would require a fender roll.. but thats no big deal. most shops charge around 50 a fender to roll them, or you can try and do it yourself.
Old Jul 1, 2013 | 09:05 AM
Tearik's Avatar
Tearik
oh i'm not worried about having to have it done, I just wanted to make sure.
Prior to owning this Z, I was capable of doing basic maintenance, as in oil change, change a tire type stuff
So I'm learning a lot in the Journey that is this Z.
Old Jul 2, 2013 | 04:26 PM
Waiz's Avatar
Waiz
I would go ahead and pull the trigger on this setup, you can always add spacers later but I would recommend against it considering that 18x9.5 (+15) is aggressive enough for the rear without getting excessive
Old Jul 2, 2013 | 04:53 PM
Tearik's Avatar
Tearik
thats good to hear.
all i'm waiting on now is to make sure i have my school this semester covered
just got back from afghanistan so I have to get my fafsa and what not done.
Then its wheel time!
Old Aug 13, 2013 | 09:47 PM
Irontimmy's Avatar
Irontimmy
In for pics, been debating on these wheels for after fall semester
Rev_Night
Nov 7, 2020 06:00 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
_bit
Oct 2, 2015 07:49 AM
