Does my tire size have any thing to do with the slip light?
Ok so I been driving my 04 350z and I have been reading online that my tires size could be the cause of my slip light here is my size of my tires 245/45R17-R 225/50 ZR17-F
I won't to know if those are my correct size or of does fit my 350z not to sure since people put all types of sizes on a 350z but I want to know from put that has had these size of that could be the problem...The slip light usually comes on when I put the gas all the way in starting from first to second my car doesn't give it's full power cause the light keeps coming out and keeps staying on til am way later but by after 10 seconds of it being on I get tired of going fast cause that slip light...also another is when am driving in the freeway and there's small turn say like am going 45mph and merging into another freeway and if I move the steering wheel a lil to much it well come out...or when I downshift also... If the tire size isn't the problem what else could it be that's causing the slip light...it has 97,879 miles 2004 350z performance edition
Yes. Your tires are almost the same height. Your rear tires need to be a certain percentage taller than your fronts to keep your VDC happy. For instance, stock rear tires are around 9mm taller than the fronts.
Already explained in the Top 100 Questions thread...
https://my350z.com/forum/showthread....1&postcount=45
So if you were took on www.tire.com or www.tirerack.com or even your drivers side door sill, it would not say hat your stock tire sizes are?
+1 to what everyone has said, you have some funky size tires OP
No you cannot switch your front tires to the rear, you should just get a set of 245-50-17's or 235-50-17's for the rear and your problem will be solved
footballmania32
Wheels Tires
Oct 20, 2015 09:08 PM
Subarism
East Canada
Sep 23, 2015 06:09 PM
