PSA: When asking "will this rub"....
Old Jun 2, 2016 | 10:15 PM
  #321
terrasmak's Avatar
Originally Posted by MatthewBouchard
Wanna double check this setup before installing.
Wheels are (F)18x9.5 +15 and (R)18x10.5'' +15. The tires I am looking at are Hankook v12 evo2 265/35 and 285/35. Springs will be tanabe gf. I rather not pull/roll the front fenders(as i'v seen some have had to do so). Front fender screw will be trimmed along with rear fenders rolled. I also don't mind having some camber.
Would this setup cause issues or would 255/35 and 275/35 tires be a better choice to be safe?
Rear roll, front screw cut down and 99% sure you will be fine. If the front touches , grab the fender with both hands and slightly pull. Front fenders are really weak and simple to slightly pull 1/8 to 1/4 inch if needed.
Old Jun 3, 2016 | 12:00 PM
  #322
Doggman9's Avatar
Doggman9
What does the front screw cut down entail? My new 265/35s occasionally rub that screw head when going in/out drives that cause the suspension to flex. I considered removing the screw entirely but didn't want the fender liner to sag so just left it.
Old Jun 3, 2016 | 12:06 PM
  #323
travlee's Avatar
travlee
Master
i just removed mine completely
Old Jun 3, 2016 | 09:50 PM
  #324
terrasmak's Avatar
Remove it, cut it in half , reinstall and foot it till it stops. It just lets you roll the fender slightly
Old Jun 21, 2016 | 12:18 PM
  #325
Stormpooper's Avatar
Stormpooper
Default Xxr 521
- 235/40/18 front 275/35/18 rear
- 18x8.5 +25 front 18x10 +25 rear
- stock height and everything.
- on those same wheel sizes, would +12 offset be better?
Old Jun 21, 2016 | 01:23 PM
  #326
frivoloushobby's Avatar
frivoloushobby
You can find much better tire sizes for stock height. 255/40F and 275/40R are dang near identical to the stock overall diameter. With the tire sizes you mentioned you'll have more fender gap and it'll look goofy. My sizes are 255 and 275 on an 18x9f and 18x10.5r.
As for offset, someone else will have to chime in on that. I never remember the offset stuff
Old Jun 21, 2016 | 01:37 PM
  #327
Stormpooper
Thanks for the advice! What about the tire sizes I mentioned if I was dropped an inch or an inch and a half?
Old Jun 23, 2016 | 03:11 PM
  #328
Jx3's Avatar
Jx3
Having a hard time wheel shopping on craigslist because sellers often fail to include the complete wheel specs, most of the time lacking the offset and when I ask, they can rarely tell me.
Looking at a set of 19s, ad says 9.6" front and 10.8" rear. Purchased for an Infinity q50.
My tires are 245/35 and 275/35
Without knowing the offset, is it possible to know if they will fit or not?
Thanks all!
Old Jun 23, 2016 | 03:35 PM
  #329
MicVelo's Avatar
350Z/370Z Tech Moderator
Thanks all!
Simple answer: No.
You can look on the back of the wheel though - sizing on quality wheels are usually marked somewhere on the mounting surface or spokes.
Q50 (and every Z34) uses front wheels with approx. +47mm offset. If the seller bought the correct sizes for the Q, they will have high offset. They will fit Z33 but will require spacers in front to bring the scrub radius back in line with what a Z33 needs... +15 to stock +30 (or a tad more in some cases).
Oh, and "9.6" and "10.8" are erroneous figures (or maybe the seller took an actual measurement) More likely 9.5/10.5.
Old Jun 24, 2016 | 04:06 PM
  #330
terrasmak's Avatar
Thanks all!
Posting the type of wheel helps. Some wheels only have a couple available in that size and the onset is listed on the site
Old Jun 25, 2016 | 06:15 PM
  #331
Stormpooper
ESR SR5
18x9.5 +22 front
18x10.5 +22 rear
What tire sizes should I run if I plan on lowering an inch and a half?
Old Jun 25, 2016 | 11:50 PM
  #332
terrasmak's Avatar
ESR SR5
18x9.5 +22 front
18x10.5 +22 rear
The common 255/40 and 275/40 combo will be great
Old Jun 26, 2016 | 06:14 AM
  #333
Stormpooper
Will these wheels fit?
Old Jun 26, 2016 | 06:20 AM
  #334
travlee's Avatar
travlee
Master
He wouldn't tell you they would be great if they wouldnt fit
Old Jun 26, 2016 | 07:04 AM
  #335
terrasmak's Avatar
Why wouldn't they fit ?
Old Jun 27, 2016 | 03:03 AM
  #336
datingjewcake's Avatar
datingjewcake
Default Tire size/rub?
18x8.5 +25 245/40/18
18x9.5 +15 285/40/18
Stock ride height
will this rub? if so whats a common tire size combo to run with these specs without looking stretched
Old Jun 27, 2016 | 03:09 AM
  #337
travlee's Avatar
travlee
Master
Stock ride height
no you wont rub, and the most popular size is 275/40/18 rear and 255/40/18 front
Old Jun 27, 2016 | 09:57 AM
  #338
MyZ32TT's Avatar
MyZ32TT
I'm trying to see if this front set up will work,
285/35/19
TE37 19.5x9.5 +22
Stock nismo suspension
Old Jun 29, 2016 | 07:48 AM
  #339
Phenom's Avatar
Phenom
Toasty
Stock ride height
You guys are gonna have some wild understeer with those tire sizes. Keep the front to rear difference in width to a max of 30mm.
Old Jul 1, 2016 | 10:21 PM
  #340
datingjewcake
i went with 255 up front and 275 in the rear. works pretty well with Nitto Invos
