PSA: When asking "will this rub"....
275 is about as wide as I'll go. I like the 17" RPF1s and got a good deal on them so that's why I'm double checking. The wheels should clear even with brembos but might give an issue with a big brake kit. Oh yeah and I have SPC camber arms in the back, not like it makes a difference with this fitment.
If this question was phrased to me, then the answer is yes.
Im trying to figure out exact how much wheel I can fit under the car. And without any of the fender to lip stuff the stance guys like. My end goal is to get a 335/30/18 on the car with an 11.5-12" wide wheel.
https://my350z.com/forum/wheels-and-...hread-116.html
So my TE37SL's just got delivered today. And I am looking at rubber now. I have been doing some research on here and feel somewhat confident. Just need approval from the pro's.
Let me say this. I'm looking for a meaty tire setup. I don't like the stretched look at all. So I guess I have multiple questions. Will it have a stretched look? Will it rub? Will I have any VDC issues? From my research I "think" I should be good. Worried about the rear rubbing tho.
- 2007 350Z
- No Roll
- Lowered on Swift Springs (-1.2F, -1.0R)
- SPC Rear Adjustable Camber Arms installed already (don't remember what camber is set at, it was within OE specs tho)
- Z1 Adj. Front Upper Control Arms ordered (not yet installed, will be before new rim/tire install)
Front: 18x9.5 +22 offset (255/40-18)
Rear: 18x10.5 +22 offset (285/40-18)
Thanks guys
- 2007 350Z
- No Roll
Thanks guys
- 2007 350Z
- No Roll
Thanks guys
- 2007 350Z
- No Roll
Thanks guys
Rear tire size is fine, but 275/40-18 also works great and has a lot more availability
Thanks gents for the responses! Much appreciated! Rims came in yesterday! WOOHOO!
@terrasmak - After looking at the rim/tire calculator on here, the 285/40 kept me closer to the stock OD. Ordered them last night. The 285/40's were only $5 more than the 255/40's. They had to order them all anyway. But I will keep that in mind about the 275's. Would I have any issues with VDC with those 275/40's, you think?
350Z/370Z Tech Moderator
To visualize the fit, here's mine in same configuration (mine are 19s but almost exactly the same overall diameter and width being 35 aspect): https://my350z.com/forum/2003-2009-n...l#post10881561
As was mentioned, you'll likely need a roll. Can't tell you for sure because I didn't roll my fenders for the wheels pictured at link above; but these +22s fit almost the same as the RPF1 9.5 +15s I DID roll them for so best to figure on rolling.
Thanks for confirming that Mic! And for the visualization! That's a nice collection of rims and tires you have! Lol
No worries. I already have a fender roller on order and should be here soon! Thanks again guys for all your feedback!
2 × 18x9 +35
2 x 18x9.5 +15
spc rear camber arms, new springs and roll bars coming in the future with possible .5 - 1" drop. These are used RPF1s with 235/40/18 tires on all four and I plan on going 245-275 stagger setup once the tires need replacement. Any issues? I need a 20mm spacer for the front to get a flush look right? How about 17x9+22 and 17x10+18 instead with 255/285 tires?
2 x 18x9.5 +15
gram lights 57cr 18x9.5 +22 or +12 (havent decided on offest up front) 18x10.5 +22 rear. Idk how to figure tire size out but figured i would run something like 275/35/18 rear and 245/35/18 up front. Cat will be stock height for the forseeable future. with just sway bars and end links at the moment.
You can always run 10.5 all around with 275/35-18 front and rear
Found a good deal on some 235/45-17 and one of my rear tires is dry rotted and leaking sure getting low on tread so it's time to replace I have an all stock 2004 350z base model stock wheels will they work on the rear? Right now I'm running 235/50-17 if I'm correct these are an inch taller same width
Don't cheap out on tires unsuitable for the car.
