will 225/45/17 fit?? please help
Old Nov 9, 2013 | 02:50 PM
buffalo_vr4's Avatar
buffalo_vr4
Default will 225/45/17 fit?? please help
my current stock wheel/tire 225/50/17 front and 235/50/17 rear, but found a good deal on a set of snow tires all four 225/45/17, will this fit my stock wheel? any downside to using this size? thanks
Old Nov 9, 2013 | 09:27 PM
Calidank223's Avatar
Calidank223
Will it fit? Yes
Might mess up TCS.
Old Nov 9, 2013 | 09:42 PM
terrasmak's Avatar
Should work fine, but I would run a 50 series for a little more ground clearance.
Old Nov 11, 2013 | 10:31 AM
buffalo_vr4
thanks guys.
Old Nov 11, 2013 | 04:57 PM
Spike100's Avatar
Spike100
225/40-17" won't work properly.
The worst problem happens if your car has VDC. TCS and ABS won't work correctly with this size.
--Spike
Old Nov 16, 2013 | 09:52 PM
buffalo_vr4
the size is 225/45//17 not 225/40/17.
Old Nov 16, 2013 | 09:59 PM
terrasmak's Avatar
As I mentioned, they will work. But as Spike mentioned can cause TCS/VDC problems, but I suspect those systems will be turned off for driving in the snow. Spike should be able to answer a bit better than me on the winter driving aspect.
Old Nov 17, 2013 | 08:58 AM
Spike100's Avatar
Spike100
My fault …typo…
225/45-17” is quite short for the rear which a 225mm on a 17” wheel should be 225/55-17”
Old Nov 17, 2013 | 03:56 PM
buffalo_vr4
i decided to go with the 225/50 instead because i dont want to mess up anything and higher ground clearance would be better. thanks for all the replies.
350z82
Oct 1, 2015 06:25 PM
