17" Wheel Suggestions
Old Nov 20, 2013 | 02:58 PM
04SilverBulletZ's Avatar
04SilverBulletZ
Default 17" Wheel Suggestions
Just purchased a full set of rims online; Drag DR-34 (17X7.55-100/11445FBF)
So yes I'll have a 04 Touring with the 17"s..hahaha laugh it up!
IMO, so far my car looks pretty damn clean!
ANYWAYS, I'm trying to get that "flush" look I keep seeing, my question is what size spacers do I need?
I prefer to use the same tires I have on my stock set-up now; 225/50 and 235/50, just as long I get them flush, otherwise I'll get new ones, but tires are still 70%-80% tread.
Thoughts on the ICHIBA V2 Spacers I keep seeing on ebay?
Old Nov 20, 2013 | 03:10 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
I hope you can cancel that order. The only offsets available in those sizes are +42 and +45 which means they will be sunk in 3/4" more than your OEM wheels. You will need to buy a 20mm spacer just to get them to stick out as far as your OEM wheels. FYI, a pair of Ichiba spacers cost as much as 1 of those wheels you bought so now you're spending all this extra money when you could have used that money to buy wheels that are suited for your car. You have some reading to do. Good luck.
travlee's Avatar
travlee
Master
it depends on the offset of the wheels.... do you know what they are.?
Old Nov 20, 2013 | 03:11 PM
travlee's Avatar
travlee
Master
dang advan, you beat me to it, i was looking them up
Old Nov 20, 2013 | 03:14 PM
pyshin's Avatar
pyshin
Jesus.
Old Nov 20, 2013 | 03:24 PM
travlee's Avatar
travlee
Master
** in his defense, i didnt know jack about offsets at first either. i didnt do wheels til about a year and half after i got the car and saw some locals cars. right now i am 18x9.5 +23 in the rear and 18x9 +30 in the front... about to change, i ordered new rears 18x9.5 +15 and the current rears are going to the front
Old Nov 20, 2013 | 03:57 PM
04SilverBulletZ
Well poop! Wonder if they sell 17" but a wider rim. I'll have to check all this out after the gym..
Old Nov 20, 2013 | 04:00 PM
travlee's Avatar
travlee
Master
they do, i have a set of 17x9 +27 (i think)... you just need to look at width and offset a little more.
Old Nov 20, 2013 | 04:55 PM
350zHalleck's Avatar
350zHalleck
Do some research like others have said. Do it right the first time instead of bandaging it with spacers.
Old Nov 20, 2013 | 05:57 PM
04SilverBulletZ
I can't find a 17x9 anywhere what the hell..
Old Nov 20, 2013 | 06:01 PM
350zHalleck
If you are looking for 17's there should be a ton of options. What makes you set on that specific wheel?
Old Nov 20, 2013 | 06:36 PM
terrasmak's Avatar
http://www.d3wheels.com/5zigen_wheels.html the FN01 is what you want.
Old Nov 20, 2013 | 06:51 PM
Waiz's Avatar
Waiz
Save more money and upsize to 18" wheels so that the options are greater
You're not doing it right if you are trying to use OEM tire sizes and are trying to be "flush" with a wider set of wheels. You will then need to get the appropriate tires for that setup and then you might as well upsize in that case
Old Nov 20, 2013 | 08:04 PM
04SilverBulletZ
terrasmak- I'm not into the five spoke so much, but I know what you're suggesting.. I'm really diggin those 5Zigen ProRacer ZR+250 in hyper gunmetal!
They have 17x9 if that works, but I see no offset and won't I need new tires?
These Rial Norano's, there 17X8 w/ 35mm offset f&r look REAL tasty, I have to call discounttire tomm and cancel this previous order ASAP
Old Nov 20, 2013 | 08:20 PM
SR71's Avatar
SR71
Lead Super Moderator
Old Nov 20, 2013 | 09:50 PM
terrasmak's Avatar
Attachment 358369
Attachment 358370
http://www.5zigen.co.jp/english/prod...l/zr_plus.html listed on the website. 17x9 +27 all around would be what you need. Then run a 10 to 15mm rear spacer when you get a chance. Then when the tires wear out, buy 275/40-17 all around.
I would go for 18's unless you autocross or hit the roadcourse.
