Rohana Wheels and fitment
Old Jan 29, 2014 | 09:26 AM
Kupalo's Avatar
Kupalo
Default Rohana Wheels and fitment
I feel in love with these rims a few years ago but with the car almost being paid off I started looking into buying them again. The seller isn't active on here and I didn't see any other Rohana accounts so I need some help.
I really want to get the RL15 in Machine or Black Matte, I found some on another site but they said they didn't fit my 2007 Z.
Can anyone help as to why they don't? I'm guessing its the offset or fitment.
07 Specs:
Front
Offset: +30mm
Weight: 24.4
Tire: 225/45/18
Rear
Offset: +33mm
Weight: 25.8
Tire: 245/45/18
EDIT: Wheelfire says they will fit perfectly, wheelplususa say's they wont.
Old Jan 29, 2014 | 09:53 AM
Landon_G03z's Avatar
Landon_G03z
They should fit. Those are oem wheel specs so you should be good to go? But you'll need spacers for flush fitment if that is any concern
Old Jan 29, 2014 | 10:04 AM
AroundMyHorn's Avatar
AroundMyHorn
If you are spending the money on new wheels why not go wider than OEM?
Old Jan 29, 2014 | 10:07 AM
Kupalo's Avatar
Kupalo
I just haven't seen any wider rims that I really love like these, but you are right I thought the same thing.
Do I need spacers because of the +37 offset? What's the highest I can go without spacers? I've heard some horror stories and being a noob I don't trust myself trying to go that route.
Old Jan 29, 2014 | 10:31 AM
07maximan's Avatar
07maximan
Yeah you need them to push the wheel out more. If you put a 25mm spacer in there it will now be +12. Thats what I run with my spacer. However im not a fan of such big spacers. I think if you need more than 15mm you should look at different wheels.
Old Jan 29, 2014 | 10:44 AM
Kupalo's Avatar
Kupalo
I could get away with a 7mm spacer on the front and a 4mm spacer on the back right? Since OEM offset is 30/33 respectively. Since the only different is that these are 0.5 inches less wide than OEM.
Old Jan 29, 2014 | 10:52 AM
AroundMyHorn
If you haven't bought the wheels yet say NO to spacers and NO to those wheels and do it right the first time by buying the right size wheels. The safest sizes for the Z without modifying anything are 9.5 +22 for the front and 10.5 +22 for the rear.
Old Jan 29, 2014 | 12:34 PM
Waiz's Avatar
Waiz
I really don't like that design and they are most likely heavy, if you insist on running them they should work on your car they will just be very conservative in both width and offset
Can we please talk you out of this? There are so many affordable choices you could go with that will be much easier for you to fit on your car that there is no reason to settle on a wheel with such sunk offsets and questionable quality
Old Jan 29, 2014 | 01:53 PM
dcains's Avatar
dcains
Agreed with Waizzz. You can do so much better with quality, look, and especially fitment. What's your budget for wheels and tires?
Old Jan 29, 2014 | 05:55 PM
Kupalo's Avatar
Kupalo
This is very helpful, I'll look for rims in these sizes then because spacers do scare me.
Yes please, link me some of your recommendations because you guys know more than I do. I was only going on the look, I didn't look into the quality yet and I knew they'd be a hard fit.
I'm looking to keep the rims under $1000 but there's something I really like I might stretch to let's say... $1200.
What would you guys recommend I do with my OEM rims? Refinish them and sell or use them in the winter and throw summer tires on these?
Old Jan 29, 2014 | 10:21 PM
dcains's Avatar
dcains
It's a personal choice, but it's important to get the right size, especially with regard to offsets. Look for something light (maybe 22-23 pounds is reasonable for a cast wheel), and made by a proven, known manufacturer. If you want new, replicas will be in your price range, like Enkei, Varrstoen, Rota, XXR, and they're decent quality for non-track use.
How about the Rota P45 - sort of a Rays/Nismo LMGT4 rep? When you're looking at those, they make a P45F (front) and P45R (rear), just like the Nismo wheels.
https://my350z.com/forum/wheels-and-...rs-thread.html
You could also be patient, like I was, and wait for a set of real used LMGT4's, which are at the upper end of your price range, and truly a top-end wheel.
https://my350z.com/forum/wheels-and-...ls-thread.html
