Tire pressure senser Question.
Old Feb 1, 2004 | 12:10 PM
Bassmaster's Avatar
Bassmaster
Default Tire pressure senser Question.
Thinking about going with 19'' rims And NOT installing my TPS. Will this set off any alarms or lights That wont turn off.
Thanks
CS Track
Old Feb 1, 2004 | 12:22 PM
MCopare's Avatar
MCopare
I am wondering the same thing....
Old Feb 1, 2004 | 12:44 PM
drew703's Avatar
drew703
Nope, you'll be fine as long as you keep the same overall height of tire + wheel. I just got my 19's put on Friday, and ZERO problems with the car (lights/alarms as you put it) The only difference is, your tire pressure gauge on your on-screen comp thingy will just read -- for the tire pressures.
As I was saying about overall height, if you're going with 19's the size you should have is 35 for the tire sidewall height. Some people go with 30 but that usually throws off the vdc or will cause those "lights/alarms" But after a few days or weeks the computer just finally "gives up" trying to figure out the new tire/wheels.
-drew
Audito350Z's Avatar
Audito350Z
the light will come on to indicate low tire pressure.... after a while it will go off.
my racing wheels dont have the TPS and I'll drive for three or four days with them and not get any lights
Old Feb 1, 2004 | 12:55 PM
ZRAYGO's Avatar
ZRAYGO
If you buy volk rims (like i did) the tire pressure sensor will not fit (no matter what you do).
Old Feb 1, 2004 | 02:31 PM
ares's Avatar
ares
Veteran
mine, the tire pressure stayed as dashes. it came on whenever the car started, but didnt beep. generally annoying.
from what Ive heard, if your pressure was low when you removed them, itd be a problem(my pressure was low). others say that even if it was good when you took them out, it would set it off again after a long drive.
Old Feb 2, 2004 | 05:16 AM
ZilvahZ's Avatar
ZilvahZ
Yup, I got the same thing. "Tire Pressure Low" light came on after being on the road for more than a half hour and stayed on. Started the engineer up this morning and it reset itself back to no "pressure low" light.
Old Feb 2, 2004 | 06:35 AM
Static's Avatar
Static
Why do you say that? This guy seems to have gotten them to work on Volks..
https://my350z.com/forum/showthread....0&pagenumber=1
Old Feb 2, 2004 | 07:10 AM
gabe33's Avatar
gabe33
What type of Volk rims did you get and why don't the sensors fit? I'm thinking about getting Volk GTC's but I want the tire pressure sensor to work. Are you sure they won't work with them?
Old Feb 3, 2004 | 09:46 PM
Bassmaster's Avatar
Bassmaster
I bought LE37 and just assumed they wouldnt work. Now I'v read somewhere that you can mount stock TSP on this type of Volk just like you can stock wheels. If someone can confirm this then I'll give it try.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
sales@czp
Sep 23, 2019 03:30 PM
