Track Setting with 275/35 18 front
Old Dec 30, 2014 | 11:32 AM
Nabush's Avatar
Nabush
Default Track Setting with 275/35 18 front
Hi,
So for now, for the track i use :
Front : 8.5*18 Rays LMGT4 with 245/40 18 R888 tires
Rear : 9.5*18 Rays LMGT4 with 275/40 18 R888 tires
In order to improve the grip of the front, i want to go wider.
I'm considering to buy ENKEI RPF1 9.5*18 for the front (don't care of the difference between front and rear in terms of style for the track).
I will put 265/35 or 275/35 18 Toyos R888 on it.
I have 2 options in terms of offset :
+15 and +38.
Will the +15 with 275/35 tire fit without rolling the front fenders ? i have about -2.4° degree of camber in the front.
Some say that 285 can fit but i don't know the offset of their wheels, and if possible i don't want to use spacers to save weight...
I'm afraid the +38 will need spacer in order not to touch the control arm... Because i tried my LMGT4 without my H/R Space (30mm, 15mm each side) and the tire 275/40 18 rubs the control arm. But the 275/35 will be smaller in height... With the spacer, which equal to about +20 it fits but it's close to the fenders...
My car is low
Thanks
Old Dec 30, 2014 | 11:45 AM
iideadeyeii's Avatar
iideadeyeii
This is what an 18x10.5 +15 with a 275/35 tire looks like at stock height.
Old Dec 30, 2014 | 11:54 AM
iideadeyeii
you said 9.5, but if a 10.5 fits then the 9.5 will
Old Dec 30, 2014 | 12:20 PM
Nabush's Avatar
Nabush
Hi,
When i look at your picture, it seems it will rub the fenders in hard cornering and bumps...
Old Dec 30, 2014 | 12:29 PM
iideadeyeii
Not sure. It's not my car /shrug
Old Dec 30, 2014 | 01:16 PM
terrasmak's Avatar
Originally Posted by Nabush
Hi,
You will want extra front camber for track use anyhow that will make it clear.
Old Dec 30, 2014 | 01:45 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
You'll be fine with the lower offset with the 275s as long as you dial in the appropriate amount of camber. Many run 285/35/18s in the front, usually with RPF1s that are 18x10.5 +15, without pulling the fenders with some healthy negative camber.
Old Dec 31, 2014 | 07:17 AM
Nabush's Avatar
Nabush
I have around -2.4° of camber. I'm not at the max of my Cusco upper arms, i think i can go up to -3°. But the wear is fine with -2.4° so i didn't put more.
I will try then.
Thanks
Old Jan 1, 2015 | 06:40 AM
terrasmak's Avatar
I will try then.
Thanks
Since you have front adjustable arms, order a set of 10.5 +15 for the rear, run your 9.5's up front and throw 275/35 or 265/35 up front. Simple and easy.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
SharX59
Sep 30, 2015 10:54 AM
Dymsi
Sep 29, 2015 11:32 AM
samansharif
Sep 25, 2015 12:31 PM
