Tire question about new wheels I bought
Old Jun 7, 2017 | 05:09 PM
bigtond's Avatar
bigtond
Default Tire question about new wheels I bought
I just bought a set of used 19" work vs xx wheels for my 03 g35 coupe. The guy I bought them from had almost no information on the wheel specs as they were off a car he bought and he did not seem very knowledgeable. I've been doing a bunch of reading as I'm pretty much a newbie when it comes to all of this but I believe the specs are
Front: 19x8.5 E+40
Rear: 19x9 E+42
And I'm wondering what size tires would be good/ideal with cost in mind for the fitment as I'm a bit confused with what to go with. I have some pics I've attached if these are of any use. Forgot to mention the car is at stock height and the guy sold the wheels with four 114.3 5 bolt spacers
Thanks
Attached Thumbnails Tire question about new wheels I bought-18986566_10154874527449811_1194671846_o.jpg   Tire question about new wheels I bought-19022501_10154874527524811_1637866224_o.jpg   Tire question about new wheels I bought-19047127_10154874527574811_875558349_o.jpg
Old Jun 7, 2017 | 05:47 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Front: 19x8.5 E+40
Rear: 19x9 E+42
Thanks
Tires.... 245/35-19 Front and 275/35-19 Rear
What size are the spacers (width)? Depending on how you like the wheels to fit, you will need to run AT LEAST 20mm spacers for them to look decent; but not much more otherwise you run the risk of taking out steering feel due to scrub radius issues.
But never mind the techno jargon, suffice that those Honda-size wheels should not be run without spacers on a Z, offset is way too high and the wheels/tires will look like an infant in a full size tub....sunken in and "small".
Old Jun 7, 2017 | 06:09 PM
bigtond's Avatar
bigtond
Thanks for the response, I have the wheels and spacers at work right now so I'll measure the spacers tomorrow however I do believe they are actually 20mm spacers
Old Jun 8, 2017 | 11:54 AM
jdmfetish's Avatar
jdmfetish
G35 coupe can take more aggressive fitment than 350Z AFAIK
I like offsets of +12 F & +10 R on 350Z
that said at least single digit on G35 coupe so i would want + 0 F & R and those offset you have are too high and 5 x 120 not 5 x 114.3
anyways even with 25 mm spacers your looking like sucked in
LOOK HERE *********** http://rimtuck.com/search/thumbnails...5+coupe&sort=1
Old Jun 8, 2017 | 11:57 AM
jdmfetish's Avatar
jdmfetish
19" VSXX + 12 & + 10
Old Jun 8, 2017 | 02:47 PM
MicVelo's Avatar
Originally Posted by jdmfetish
... and those offset you have are too high and 5 x 120 not 5 x 114.3
Uhhhh, did I take a wrong turn and end up in the BMW forum somehow?
EDIT: Ooooops, just saw why you said that... ooops. Maybe those "spacers" are 5x120 == > 5x114.3 *adapters*....one hopes.
Old Jun 8, 2017 | 03:22 PM
deeliciousqueen's Avatar
deeliciousqueen
I have g35 coupe as well, 19x8.5F+27 & 9.5R+24 & went with tires sizes mentioned above cuz I am not a fan of stretch tires. Had to use 20mmF and 15mmR to get the flushness I want.
Had a $100 rebate at the time for a set of Hankook evo2 so great deal!
Old Jun 9, 2017 | 11:38 AM
rearranged's Avatar
rearranged
Sell those wheels and get wheels that are correct offset(+12-22, stock is +30f +33r) and 5x114.3. If you have to use adapters then you don't want spacers with the adapters. That sounds like a recipe for disaster. Next time, if you're not sure, come here and ask before you buy wheels you know nothing about.
Old Jun 9, 2017 | 11:55 AM
iideadeyeii's Avatar
iideadeyeii
Front: 19x8.5 E+40
Rear: 19x9 E+42
LOLZ
Old Jun 9, 2017 | 12:59 PM
rearranged's Avatar
rearranged
Originally Posted by iideadeyeii
LOLZ
Don't forget the 5x120
Old Jun 9, 2017 | 02:35 PM
MicVelo's Avatar
Wellllllll, those 40+ offsets need a big spacer, right? Bolt pattern adapters are usually 25mm thick so if they ARE *adapters*, it could still work.
Why, no, I wouldn't do it; but the way I look at it, if one has to use them to fit those wheels, the 25mm taken off the offset of those wheels make them +15 and +17, so what the hey.
Old Jun 10, 2017 | 02:32 AM
rearranged's Avatar
rearranged
Mic, you're such a ray of sunshine. It's good we have you to keep a positive spin on things.
Old Jun 10, 2017 | 09:59 AM
MicVelo's Avatar
Awww shucks, izz only cuz I's only a half full kinda guy. Why, just last night at a friend's party, "Gee, Cy, only half full?? C'mon, man, fill me up! Don't be so stingy with the Calumet!"
