+15 or +22? Flush-ish Fitment
Old Jul 5, 2017 | 06:55 PM
TristanZ's Avatar
TristanZ
Default +15 or +22? Flush-ish Fitment
Trying to get fitment along the lines of these two cars, specifically the black one. The red has a little too much camber in the back but is still pretty similar. Do you think it would be better to just get +22 and use spacers if need be, or do you think +12 would be enough to get that "tucked & flush" sort of look that the black car has? Of course I would want to avoid spacers if possible. 19x9.5 in front and 19x10.5 in back, only offsets available are +12 and +22. Thanks for the help.
Pic is too big, link http://imgur.com/96Ea32r
Old Jul 5, 2017 | 07:56 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
All depends on tire choice and suspension. Lowered modestly and on 9.5/10.5, running 255/35 & 285/35 works just fine so long as you plan to or have rolled your rear lips.
No pics on this computer away from home but you can find a couple of examples here:
9.5/10.5 +22 (both) example here: https://my350z.com/forum/2003-2009-n...l#post10881561
And +25F/+12R in a post just above the one above or by clicking here: https://my350z.com/forum/2003-2009-n...l#post10865508
Old Jul 5, 2017 | 11:33 PM
terrasmak's Avatar
Do you want proper tires are stretch stuff?
Old Jul 5, 2017 | 11:36 PM
TristanZ's Avatar
TristanZ
I'd be fine with a minor stretch, but the car is my daily so I can't go too crazy with it. Currently on stock suspension right now too.
Old Jul 6, 2017 | 08:25 AM
iideadeyeii's Avatar
iideadeyeii
+22 Extends 40mm past factory wheel in the rear. Go measure
Old Jul 16, 2017 | 06:09 PM
guitman32's Avatar
guitman32
Get the +12, from the sound of things if you get the +22 youll probably end up with spacers.
Old Aug 3, 2017 | 02:41 AM
ohatebasehr's Avatar
ohatebasehr
currently running 19x10.5 +22 and needs spacers front and rear. if flush fitment is what you're aiming for. go +12. otherwise you'll be buying spacers also.
Old Aug 3, 2017 | 02:45 AM
ohatebasehr
235/35 front 255/35 rear.
Old Aug 3, 2017 | 04:11 AM
travlee's Avatar
travlee
Master
you would be better off running a 255 up front and 275 rear... unless you like the stupid stretch look
Old Aug 3, 2017 | 04:45 AM
MicVelo's Avatar
Needs spacers? I dunno... personally think it'd be a disaster to put spacers on these +22s...
Or maybe I'm not at the definition of "flush"? Hmmm, where's the bathroom at? FTR, I hate the term "flush".... I prefer "tire contact patches maximized to the available track width without negative effect to the scrub radius."
But that's just my preference.
Old Aug 3, 2017 | 07:07 AM
iideadeyeii
That's sticking out wayy past fender. +22 would have been perfect by itself, but why get 10.5" wide wheels if you're not going to get a tire that fits properly. Seem's like you're adding weight for nothing. Should have gotten 8" wide for those tire sizes
Old Aug 3, 2017 | 12:59 PM
CJM's Avatar
CJM
This "flush" conversation is pointless without talking about your ride height. The two pictures below are the exact same wheel & specs. Only change is the ride height. The natural camber from the car being lowered will effect the appearance of "flush"
Old Aug 3, 2017 | 03:00 PM
MicVelo's Avatar
Nice compare. Only thing that would fluster me is the change in steering response. Notice much diff on curvy roads/track between the two camber "settings"? What is the front at when dropped like that?
Old Aug 3, 2017 | 04:46 PM
CJM's Avatar
CJM
The lower picture is fully aired out so I definitely could not drive like that. At ride height the front camber is only 2 degrees. Aired out I have no idea. So whenever I drive, the steering response remains constant thankfully.
Old Aug 3, 2017 | 07:01 PM
MicVelo's Avatar
Ahhhhh, yeah, forgot that your car is on air.... thought they were before/after suspension mods pics. (And in a way it is. ) But again, great perspective on this.
Old Aug 8, 2017 | 09:31 AM
cincysilvias14's Avatar
cincysilvias14
im having the same issues deciding offset as well. if the +22 is going to push 40mm off then no thanks. ill stick with the +12 (gram lights)
Old Aug 8, 2017 | 12:59 PM
rancor's Avatar
rancor
The +12s will push the wheels out 10mm further than the +22. The amount they will stick out is also dependent on the wheel width.
Old Aug 14, 2017 | 06:11 AM
cincysilvias14
offset is so damn confusing lol i do want to go flush but not sure if i should use +12 around with 9.5in. wide up friont 10.5in. in the rear
Old Aug 14, 2017 | 06:41 AM
ohatebasehr
top picture is 19x9.5/10.5 +12 and +15. Bottom picture is 10.5 all around +22
Old Aug 14, 2017 | 10:42 AM
MicVelo's Avatar
https://my350z.com/forum/wheels-and-...t-novices.html
Gee, when I wrote that, never thought it'd come in handy to anyone....
