05 Base model Wheel upgrades thos
Old 09-14-2017, 12:08 PM
Rhaneline
Rhaneline's Avatar
Default 05 Base model Wheel upgrades thos
So ive been doing a lot of research and i'm still a little confused on offset and the staggering of 350z wheels. So today i have two to three questions pardon me if it's a constant duplicate on here. The stock base model Z for 05 has Front: 17x8 with a 30mm offset
Rear: 17.8.5 with a 33mm offset?
not sure if those are right which is why i'm here. i wanna buy some 18" but i'm not sure what's more reccomended not better, a lower or higher offset and is the staggering required when it comes to 350z wheels?
Old 09-14-2017, 12:26 PM
travlee
Master
travlee's Avatar
Received 9,048 Likes on 6,514 Posts
Jeebus........Been covered a million times...
18x9.5 +15 on all corners or 18x9.5+15 front and 18x10.5 +20(ish) on rear
with 255/40/18 front tire, 275/40/18 rear
/ thread
The following 2 users liked this post by travlee:
iideadeyeii (09-14-2017), jhc (10-03-2017)
Old 09-14-2017, 12:40 PM
Rhaneline
Rhaneline's Avatar
/ thread
i know i'm sorry for the hassle i just can't find the exact information i'm looking for, and i'm pretty new into the car world spoiled myself with a Z as my first vehicle.but the wheels do not have to be staggered but is it recommended? with 18x9.5 a +15 offset and with a 18x10.5 a 20+ offset would sit flush?
Old 09-14-2017, 12:41 PM
travlee
Master
travlee's Avatar
Yessir.... will have to roll the rear fenders if you are lowered
Old 09-14-2017, 01:10 PM
Rhaneline
Rhaneline's Avatar
still stock height so i wouldn't have to roll them until i bought coils, thank you!
Old 09-14-2017, 01:37 PM
350Z/370Z Tech Moderator
MicVelo's Avatar
Received 3,255 Likes on 2,316 Posts
With +15 rears, you may still experience a bit of fender interference going over bumps and dips. Stay away from the latter, like Travlee.
Keep in mind that the offset requirements vary with the width of the wheels and the size of the tires.
Understanding offset:
https://my350z.com/forum/wheels-and-...t-novices.html
While a 9.5/10.5 combination is pretty much about the most maximized configuration with all other aspects of the car taken care of and optimized for your type of driving, e.g., suspension and alignment, the 8.5/9.5 or 9/10 combinations work very well too.
Old 09-14-2017, 01:56 PM
dboyzalter
6 inch cawk is my fave!
dboyzalter's Avatar
18x13 with -75 offset and fender flares. 325/30/18 all around... You will have no traction issues and will corner like a boss.
Atreyu'z 350 (09-14-2017)
Old 09-14-2017, 02:31 PM
MicVelo's Avatar
Yeah, boss dboyz, I'm diggin' whatchu done did to your wife's Juke!! Bishin'!
Old 09-14-2017, 03:55 PM
dboyzalter
dboyzalter's Avatar
Old 10-03-2017, 12:36 AM
Zkiwi
Zkiwi's Avatar
Something wrong with the culture here that you can't get a straight answer.
Stock 18's on 2005 changed to a small staggering for the Anniversary I think. Regular 18x8 30p front and back worked for a long time so I'll say staggering is not essential but the difference in overall diameter from different width front and back is factored into traction control computer. So a stock 245/45 rear and a 225/45 front. Whatever tyres you go with should maintain that small ratio in rolling circumference whatever it is.
There are not many 18" 30p wheels out there. They are all 8.5''.
I have done a lot of reading and not found much explanation of how offset relates to wheel width in the alignment sense, as opposed to fitting the biggest fine wheel and tyre possible within the arches. I believe contact patch centre shifting inboard with less offset can leave no scrub radius or not enough scrub to stabilize the straight ahead condition so the steering feels loose.
I believe a 18x8.5 30p should put the tyre in the same plane as a 8.0 with 30p.
Old 10-03-2017, 12:39 AM
Zkiwi
Zkiwi's Avatar
Of course a base model has no traction control to worry about but I saw a photo somewhere that showed both ends on same tyres and it looked a bit gawky high in the front to my eye. That little bit of downhill lean to the front is what looks normal and correct I guess.
Old 10-03-2017, 03:00 AM
travlee
Master
travlee's Avatar
why do you want the wheels sitting in? go with something in the range of +15 to +low20s... and ditch the 8.5, and go with a 9.5 width
Old 10-03-2017, 03:46 AM
dboyzalter
dboyzalter's Avatar
Because it's so difficult finding threads on this topic
Not to mention the first answer was a straight one...
/ thread
travlee (10-03-2017)
Old 10-03-2017, 04:55 AM
MicVelo's Avatar
Something wrong with the culture here that you can't get a straight answer.lieve a 18x8.5 30p should put the tyre in the same plane as a 8.0 with 30p.
Jeebus, really?? The first 6 comments on the thread answered the question with re-directs to other helpful articles. After those ANSWERS, the thread took a turn for the humorous. Man, not exactly sure what more spoon feeding you think this thread needs that hasn't been covered already in a 3,747 other threads. At least this one didn't just say "Search, newb!!"
Old 10-03-2017, 02:20 PM
Zkiwi
Zkiwi's Avatar
see, this is where I feel the residents have got it all wrong. The equiry was never answered. "What is stock 18" rims looking like?".
The link is about offset and it's a hoot. To find an unknown offset measure down from straightedge and subtract half the overall. Or find where it's stamped on there.
How did the first response get to 10.5's? Answer the question asked then discuss why it's not an appropriate question. I happen to think it's an entirely appropriate one since 2005 was the start of staggered stock rims.
It's my guess Nissan brought in wider rear rims and increased the offset so it stayed looking stock. That would have narrowed the track at the rear. No change on front.
I haven't read anything to say why 18x8.5 30p 245/45 rear, 18x8.5 30p 225/45 would be wrong. That's the stock tyres with option to go wider.
Old 10-03-2017, 03:15 PM
dboyzalter
dboyzalter's Avatar
Your not understanding the original question. He wants to know what will look good and does he need more or less offset. Nobody wants to buy wheels and have them look like they are sunken in.
Wider wheels with a lower offset give a nice flush look... Oem wheels and sizes give a sunken in appearance.
All you need to do is throw an 18 in the 17 spot if you want crappie oem 18 fitment... If your into skinny wheels like 8.5s you would want a 0 offset to fit flush.
Old 10-03-2017, 03:55 PM
dboyzalter
dboyzalter's Avatar
Also if you look up at the top of the page under the tools tab they have a tire and wheel calculator... Anyone in the market for a new set should probably visit that tool before finalizing any orders.
Old 10-03-2017, 03:59 PM
travlee
Master
travlee's Avatar
Meh, let his car look like a skateboard rolling on cheerios
Old 10-03-2017, 04:14 PM
Zkiwi
Zkiwi's Avatar
A zero offset?
My Z is on stock non staggered 18x8 30p. Is that what you think of as cheerios on a skateboard?
Old 10-03-2017, 04:59 PM
travlee
Master
travlee's Avatar
Sir yes sir
