tire width 275 or 285?
Old Feb 21, 2004 | 09:38 AM
JJGALIA's Avatar
JJGALIA
Question tire width 275 or 285?
Do they make a 285/35/19 tire? And if so why is everyone going with the 275? Is 285 too much rubber for the stock Z? Thanks Jim
Old Feb 21, 2004 | 11:10 AM
lowrider's Avatar
lowrider
275/35/19 is the recommended size to go along with 9.5" wheels and 245/35/19s up front. It maintains the correct stagger and improves the handling of the car. 285/35/19s are made by many tire manufacturers, and will work just fine. They are slightly wider and taller. However, they do fall into the range of a tire that will work fine on the "Z" or "G". People who want the largest of everything will choose this size.
275/35s however, are optimal on the proper 19" wheel.
Lou
Old Feb 21, 2004 | 11:19 AM
JJGALIA's Avatar
JJGALIA
I was just trying to make an informed decision before I placed my order. Thanks lowrider.
Old Feb 23, 2004 | 06:43 PM
grutter's Avatar
grutter
What about 19x9.5+22 front and 19x10.5+22 rear ?
The 275/35 appears 'stretched' to me on a 10.5" rim. Is the 285/35 a better fit for the rears with 10.5" rim.
Any rubbing issues ?
What would be the proper tire size for the fronts ?
If 275 is the "right" size for a 9.5" rim, would you run this on the fronts, or go to a 255/35 ?
Old Feb 23, 2004 | 07:30 PM
Ricky's Avatar
Ricky
I have 285 on my 19x9.5 and I love it. The 275 seem a bit stretched to me. Also doesn't offer enough lip protection. The 285's give a slight protection, and still handles perfect to me.
Old Feb 23, 2004 | 07:52 PM
AmyCroft's Avatar
AmyCroft
Smile Good Point - Rim protection
Ricky, Good point about the rim protection..
I like the look of "Full" and not "streched" also.
Cheers
Old Feb 23, 2004 | 07:59 PM
___DJK___'s Avatar
___DJK___
285 gets my vote
Old Feb 23, 2004 | 08:04 PM
grutter's Avatar
grutter
I have 9.5 front and 10.5 rears on the way soon...
Don't want the stretched look, front or rear.
Any recommendations ?
How wide can you go in the front if running 9.5" rims ?
Old Feb 23, 2004 | 09:02 PM
ares's Avatar
ares
Veteran
275 front 295 or 305 back. depending on offset you may need to roll your fenders front and/or back. 295s are less likely to need it vs 305. but itll be close.
Old Feb 23, 2004 | 10:26 PM
fluidz's Avatar
fluidz
go with 285.........i have 275 and next time a bit wider would be perfect!
Old Feb 23, 2004 | 10:57 PM
ypwpat's Avatar
ypwpat
Um has anyone heard Hankook Tyres brand? I just wondering if they are good or not? Because i have a good package deal with 19" SF-winning with Hankook Tyres
Old Feb 24, 2004 | 07:27 AM
al503's Avatar
al503
I have to agree with the 285's on 10.5" wheels. I just got the Racing Harts CP-F Tuned with 10.5 in the back and 275 GS-D3's. When I ordered them, I figured that they wouldn't have the 'stretched' look because 275mm / 25.4 = 10.8" I wasn't a math major but something doesn't add up.
I don't think 285's will get rid of all of the stretched look but it would help some.
Old Feb 24, 2004 | 08:16 AM
ares's Avatar
ares
Veteran
295 is better for 10.5 275 is meant for 9.5" rims. yeah the width doesnt add up like that, dont ask me why not. itll go down as just one of those things, just like the screwy tire sizing method they use. why is sidewall a percentage of width? WHO KNOWS!!!
I was told hankook was a korean made tire and pretty much bottom of the barrel, they are dirt cheap about half the price of other tires the same size. Id stay away from them personally, could end up costing you a whole lot more when they lose traction.
Old Feb 24, 2004 | 11:31 AM
Yielar's Avatar
Yielar
I'm not a tire " know it all " but after reading your thread it made me think. Correct me if I'm wrong but the 285 is a measurement of the tire tread which is considerably wider than the actual bead that seals onto the wheel. Therefore the method al503 used to determine the right size tire for his 10.5 wheel will not work.
I am also in the process of choosing the best offset and wheel configeration and would like to go with 255/30/19F 285/30/19R. I don't like the stretched look what so ever and also don't want too much tire extending past my fenders. What would be an offset on GT-C's that would give me this match? I was thinking of going 8.5F and 9.5R.
Yielar
Old Feb 24, 2004 | 12:07 PM
ranger5oh's Avatar
ranger5oh
285 is a measure from sidewall to sidewall. They measure that at the widest distance of the tire. A size 285 by different manufacturers may have many different tread widths depending on the tire manufacturer.
Old Feb 24, 2004 | 02:23 PM
mgl's Avatar
mgl
285s!!!
Old Feb 24, 2004 | 02:28 PM
jak's Avatar
jak
I have 285s in the rear and 255s up front. The car handles great.
Jeff
Old Feb 24, 2004 | 02:59 PM
Yielar's Avatar
Yielar
Jeff
What wheel widths did you go with? I don't like the stretched look is why I'm asking.
Yielar
Old Feb 24, 2004 | 04:16 PM
rodH's Avatar
rodH
I went with 275, they are more close in size to the stock, and lighter (some guys don't care about this, I do). 275 is plenty fat and matches well with my 10" rear.
Old Feb 24, 2004 | 06:11 PM
jak's Avatar
jak
Yielar
10.5 on the rear and 9 on the front. Both tires sit flush to the lip. Here is a thread from awhile back with pics of my car before being lowered.
https://my350z.com/forum/showthread....&highlight=hre
Jeff
