can you use a 275/40 tire on a stock 18x8.5" wheel?
Old Nov 26, 2018 | 01:27 AM
efs101's Avatar
efs101
Default can you use a 275/40 tire on a stock 18x8.5" wheel?
2008 350z roadster
Old Nov 26, 2018 | 06:22 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Originally Posted by efs101
2008 350z roadster
Can it be mounted? Yes.
Safely? No, it's pushing beyond the safe limit. Have to assume you want a size like that for "performance reasons". Performance and safety is compromised meaning it's not worth doing.
Old Nov 26, 2018 | 09:11 AM
iideadeyeii's Avatar
iideadeyeii
I'm running a 275/40/18 on the factory 18x8 wheel for that past few years. Cornering is fine. The front 225's will chirp on corners and the rears never chirp. Honestly probably not worth the extra weight as I'm only around 300whp. I'd probably go 265's if I had to do it again just for weight reasons only.
Old Nov 26, 2018 | 04:23 PM
Spike100's Avatar
Spike100
I would not run a 275/40 tire on a stock 18x8.5" wheel. The sidewall (and possibly the car's handling) is adversely affected by this deviant wheel/tire-size combination. You should mount at least a 9.5" wide wheel if you are running a 275 mm wide tire.
Old Nov 27, 2018 | 10:15 AM
terrasmak's Avatar
I would do it with a slick or cheater slick for drag use, it something i would daily drive.
TimsZee
Wheels Tires
17
Jan 5, 2017 04:48 PM
bgant3
Wheels Tires
Nov 2, 2016 10:00 AM
3502GO
Oct 4, 2002 07:29 PM
