Wheel width upfront?
Old Nov 20, 2018 | 11:11 AM
Blackskiies's Avatar
Blackskiies
Exclamation Wheel width upfront?
How wide can one go for rims upfront? Can i do 10.5 or 11 in the front? Will there be clearance/rubbing issues that would be concerning?
Old Nov 20, 2018 | 02:25 PM
Chihuahuamaster's Avatar
Chihuahuamaster
Sorry to say, but have you searched for your question? There are many similar threads. i.e.: my350z.com/forum/wheels-and-tires.
If you're going to ask such a question, you need to provide many details such as; what is the wheel size, wheel offset, tire size you plan on running, what is your suspension setup (how low or high), do you have a stock fenders, rolled fenders, etc...
Also, is there a particular reason you want such a wide rim on the front? Many people run 10.5 width wheels in the front, but it really depends on the offset of the wheel for clearance, and the tire size if it will rub.
Old Nov 21, 2018 | 05:06 PM
terrasmak's Avatar
I run 10.5 up front on mine with a 285/35-18 , but it's also got -3.3 degrees of camber. What are your actual needs ?
Old Nov 22, 2018 | 02:33 PM
Blackskiies
i want to run it without camber...
Old Nov 22, 2018 | 06:12 PM
travlee's Avatar
travlee
Master
Old Nov 22, 2018 | 07:00 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
He meant “What are you using the car for that needs that much rubber?”
Old Nov 27, 2018 | 10:18 AM
terrasmak's Avatar
that's pointless, a wide tire is for handling and proper camber is needed to make the car handle properly.
Old Nov 27, 2018 | 10:32 AM
iideadeyeii's Avatar
iideadeyeii
I think he means factory camber
Old Nov 27, 2018 | 10:33 AM
Blackskiies
by no camber i meant factory camber...
I shouldve clarified, my bad
Old Nov 27, 2018 | 03:13 PM
Spike100's Avatar
Spike100
by no camber i meant factory camber...I shouldve clarified, my bad
Travlee nails it when he says 9.5” with a 15 mm offset. Mount a 255/40-18 or 255/35-19 tire on your 9.5” wide wheel with a 15 mm offset.
Old Nov 27, 2018 | 06:42 PM
jhc's Avatar
jhc
General & Tech Moderator
Sorry gents, he's talking about a widebody build for looks, not performance. Sorry to crash the thred.
Old Nov 28, 2018 | 05:38 AM
iideadeyeii
Show before go makes the girls go woah
Old Nov 28, 2018 | 12:02 PM
MicVelo's Avatar
As in "Whoa, found me a mate!" or....
"Whoa, stop!"?
Old Nov 28, 2018 | 12:14 PM
travlee's Avatar
travlee
Master
more like this
VoodooJC
Jan 21, 2009 09:54 PM
QuicksilverZ33
Oct 15, 2008 04:48 AM
99amgc43
Jan 15, 2008 12:22 PM
05-Z
Sep 19, 2006 06:01 AM
