Help with Work Euroline DZ offset
2003 Nissan 350z Track. Hey there, I've got the opportunity to get some authentic Work Euroline DZ Flats for cheap. They're in immaculate condition but the offset scares me. My current set up is the factory track wheels:
FrontSize: 18x8.0
Offset: +30mm
Weight: 18.19lbs
Tire: 225/45/18
Offset: +33mm
Weight: 18.62lbs
Tire: 245/45/18
The Works are:
Fronts: 18x8.5 +42
Rears: 18x10 +44
Tires: Pirelli P Zero Nero run flats
245/40R18 fronts
275/40R18 rears
I understand that I'll need spacers in the front for sure to keep my steering on point, but has anyone dealt with high + offset themselves? I'm unable to test fit and have to travel to get them so just want some personal experience to know theyll fit on the inside and out.
thank you.
FrontSize: 18x8.0
Offset: +30mm
Weight: 18.19lbs
Tire: 225/45/18
- Rear
Offset: +33mm
Weight: 18.62lbs
Tire: 245/45/18
The Works are:
Fronts: 18x8.5 +42
Rears: 18x10 +44
245/40R18 fronts
275/40R18 rears
thank you.
350Z/370Z Tech Moderator
FrontSize: 18x8.0
Offset: +30mm
Weight: 18.19lbs
Tire: 225/45/18
Offset: +33mm
Weight: 18.62lbs
Tire: 245/45/18
The Works are:
Fronts: 18x8.5 +42
Rears: 18x10 +44
245/40R18 fronts
275/40R18 rears
thank you.
FrontSize: 18x8.0
Offset: +30mm
Weight: 18.19lbs
Tire: 225/45/18
- Rear
Offset: +33mm
Weight: 18.62lbs
Tire: 245/45/18
The Works are:
Fronts: 18x8.5 +42
Rears: 18x10 +44
245/40R18 fronts
275/40R18 rears
thank you.
Off top of head, I'd go 20mm F&R and you'll be fine.
Easy fit using 20-25mm spacers F AND R. Which size you choose depends on how close to the fenders you want them to be. Use the tire calculator to determine which size: https://my350z.com/forum/tire_rim_calculator.php
thanks for your help though. New to the page 🤙
