Tire Size Options for 2003 with 8" wide wheels F/R
Old May 26, 2021 | 01:08 PM
jwilliams's Avatar
jwilliams
Default Tire Size Options for 2003 with 8" wide wheels F/R
I have a 2003 Touring 6-speed with the stock 18x8" wheels F/R. My car is lowered by 1". I have searched but did not find the answers to these below. I would like to consider the following tire options (because the good brands of performance tires are out of stock in the stock size of 225/45/18 Front, 245/45/18 Rear). Options I am considering:
1) 245/40/18 F, 265/40/18 R: Rears are a little too wide for the 8" rear wheel. However, Hankook offers the V12 in this rear size and it is significantly more narrow 10.6" overall, 9.1" tread width than other brands which typically run 11.2" overall and 9.4" tread width so I might be okay in the rear.
2) 235/45/18 F, 255/45/18 R. A little taller overall which I don't mind as long as it does not rub.
3) 235/40/18 F, 255/40/18 R. I think the stock tires look a little small in diameter as it is. This will make them even smaller.
Anyone run either above on 8" stock width wheels F/R? Other options I am missing?
Old May 26, 2021 | 01:36 PM
travlee's Avatar
travlee
Master
Who runs an 8 inch on the rear?
Old May 26, 2021 | 05:04 PM
jwilliams's Avatar
jwilliams
The stock 2003 18" wheels on touring 6-speeds is 8" wide. There are a lot of us with them.
Old May 26, 2021 | 05:18 PM
travlee's Avatar
travlee
Master
No....not really
Old May 27, 2021 | 12:27 AM
terrasmak's Avatar
Originally Posted by travlee
No....not really
03 to 05 with the 18 inch wagon wheels where 8 inch wide all around
245/40-18 front
245/45-18 rear
you forgot probably the best handling option
Old May 27, 2021 | 02:04 AM
travlee's Avatar
travlee
Master
I was saying that most people moved sway from them.
Old May 27, 2021 | 02:42 AM
jwilliams's Avatar
jwilliams
As mentioned above, I cannot get the 245 45 18 in the preferred tires. They are out of stock with no delivery dates available. This is the reason I am considered other options. I am leaning toward 235 45 18 and 255 45 18 because it would fill out the wheel wells a little better and are only 0.3" taller. Anyone put these on? any rubbing issues?
Old May 27, 2021 | 03:08 AM
travlee's Avatar
travlee
Master
wont be any rubbing issues, but will look like a skateboard rolling on cheerios
what is your preferred tire?
Old May 27, 2021 | 03:28 AM
jwilliams's Avatar
jwilliams
Pilot 4S, Conti Extreme Contact, Yoko Apex, V12 Evo 2, Gmax RS. I buy my tires at discount tire direct due to pricing. I know some others have them, but they are a lot more expensive than what I can get them for at discount.
Old May 27, 2021 | 03:44 AM
travlee's Avatar
travlee
Master
i will give ya my thoughts on some
4s - love them, had them on both corvettes
conti - wasnt impressed with them on the ats-v
v12 evo 2 - thought they wore out quick on my 350z
are you wanting to stay stock sizes due to finances? if so i get it, for future reference if you want to change the wheels, most run 18x9.5 +15 front and rear, or 18x9.5+15 (or low 20s) front and 18x10.5 +15 rear with 255/40 and 275/40 tires
Old May 27, 2021 | 04:34 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Rolling diameters are a little tall on the 235-255 combination although the F-R delta is OK and should be fine with VDC. Might rub on the front fender liner screw but that can be cut down.
Personally, I'd prefer the 245/40 & 265/40 combination as they are closest to stock rolling diameter (both a tad short but workable) EXCEPT that the 265 is bit too wide - more than the 120% rule - but will fit on the wheel. Just a tad bit of slop on 8" wheel.
FWIW, I have Conti Extreme on my Benz, which puts down way more power and has electronic active suspension and have not had a bad experience on those. Pilot Sports on my Z were well behaved of course, but mine were worn when I got the car and have since run every other brand name tire on the car BUT Mushylin. And we're talking over two dozen sets of wheels. Laff. V12 Evos are claimed to be sloppy due to soft sidewalls but have no personal experience on them. The thought of losing razor sharp turn-in response does not bode well with me. Response must be RIGHT NOW! Haha.
Old May 27, 2021 | 05:30 AM
jwilliams's Avatar
jwilliams
Anyone put a 265 40 18 on an 8" wide rear? I am concerned it is too wide because all manufactures say 9" is min width.
Old May 27, 2021 | 05:45 AM
MicVelo's Avatar
As I said... it can be installed and still be perfectly safe; but will not be optimized for performance by the 120% factor.
8" = 203mm, 1.2 x 203mm = 243mm max., rounded 245.
9" wheel = 228mm, 228 x 1.2 = 274mm max, rounded 275.
Old May 27, 2021 | 06:07 AM
jwilliams's Avatar
jwilliams
Thanks so much for your input! If it was you would you go with 235 45 18 and 255 45 18 (a little too tall) or 245 40 18 and 265 40 18 (too wide for rear wheel) with the goal of having good handling for the street (no autocross or anything crazy)?
Old May 27, 2021 | 06:45 AM
iideadeyeii's Avatar
iideadeyeii
Turbocharged and running a 275/40r18 rear tire on the factory 18x8" wheel with a 20mm spacer in the rear. Front 225/45/r18 with a 15mm spacer.
I probably would of went 20mm/25mm, but it doesn't bother me that much.
Old May 28, 2021 | 05:39 AM
iideadeyeii
Here's a better view of the 275 on the factory 8" wide wheel
MyBigNut
Aug 19, 2010 06:33 PM
chrisjersey06
Apr 10, 2009 10:33 PM
Spike100
Mar 28, 2007 06:50 PM
d!abolic
Dec 17, 2006 05:53 PM
JaX_Z
Dec 11, 2006 02:13 PM
