need help with lug issues
Old May 19, 2022 | 12:13 AM
Jethrow's Avatar
Jethrow
Default need help with lug issues
So i recently went from 20" xxr wheels (they came with the car when i bought it from a dealership, not my desired size but ok) to 18" Konig Countergrams. Im using the same lug nuts i had been but now they wont stay tightened..... I know they are proper thread pitch and all because again, i have been using them since 2020, so yeah im at a loss for ideas at this point.
new wheel specs are 18"x 9.5 / 18"x 10.5
*note* was told by tire place i called to remove the plastic rings for the old wheels so i did, but even with them on was still having this issue.
Old May 19, 2022 | 01:16 AM
travlee's Avatar
travlee
Master
Replace the lugs
Old May 19, 2022 | 05:57 AM
Heel Til I Die's Avatar
Heel Til I Die
Confirm the hub bore size on your new wheels. It looks like they're 72.60mm. The hub bore size on the Z is 66.1mm. Get some hubcentric rings that are 72.60mm OD and 66.1mm ID. I would get some metal or aluminum rings instead of those plastic rings. These are necessary with aftermarket wheels in order for the load to be distributed on the hub instead of the lugs.
Then, confirm what type of lug nuts your Countergrams use. They're likely conical or tapered. Get some new lug nuts that are M12 x 1.25mm thread size. Torque them down to 85 ft-lbs. After driving for about 25-50 miles, check the torque and re-tighten them to 85 ft-lbs, if necessary.
Old May 19, 2022 | 07:15 AM
Jethrow's Avatar
Jethrow
Ok, thanks alot, any recomendations on where to get the rings from? or does it not really matter?
Old May 19, 2022 | 07:31 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Scroll through these rings and find which suits you. Personally, I hate the metal ones. They always seem to stick in the wheels. Not a huge deal as I don't change wheels as often anymore (and, I use different rings for each set so no matter. Just OCD about having them stick.)
https://www.ebay.com/sch/i.html?_fro...TERS&_osacat=0
On lug nuts, the Countergrams (as most of the contemporary Konig flow form wheels) use a "tuner lug nut" or 12x1.25 conical type. Konig recommends "spline drive" tuner lug nuts if your wheels are double drilled (two bolt patterns, e.g. 5x114.3 AND 5x100) since the recess holes are narrower on a double drilled wheel.
Definitely follow Heel's advice. Install, drive, RE-TORQUE. They should only require a few pounds of tightening. Any more than about 15lbs, there's something wrong.... seats are different, lugs are wrong (one leads to the other).
Old May 20, 2022 | 08:29 AM
Jethrow's Avatar
Jethrow
I appreciate all the help, got em fastened, (no ring necessary) new (slightly) longer nuts and she's squared away, alignment appt Monday and it should be fine. Best Z community online right here
Old May 20, 2022 | 09:57 AM
Heel Til I Die
I would just like to point out, for the record, that this comment was made on a thread that Trav responded to. Y'know, for all the newbs that get super butthurt by his responses
Old May 20, 2022 | 10:32 AM
travlee's Avatar
travlee
Master
I may be a sarcastic *** most times, but I do try to help
And also point out stupid
Old May 20, 2022 | 11:43 AM
MicVelo's Avatar
Take out "sarcastic" and yer on to something.
Wait, did I say that out loud? Nahhh, typed it out loud.
Rex08Z
Mar 17, 2013 04:03 AM
winona78
Jan 17, 2013 07:56 PM
J1mb0
Oct 30, 2010 02:05 PM
cpapasmurf
Jul 2, 2007 06:08 AM
joegengsta
Nov 27, 2006 09:25 PM
