Tires
Old 07-05-2024, 10:34 PM
Bencapasso
Bencapasso's Avatar
Default Tires
I am currently running 245/45/18 In front and 265/35/18 in rear. Which I think is causing slip light and vdc to kick in ? Should i upgrade the rear to 265/45?
Old 07-06-2024, 09:47 PM
350Z/370Z Tech Moderator
Premier MemberSuper Moderator
MicVelo's Avatar
Received 3,302 Likes on 2,350 Posts
26.68" diameter Front
25.30" diameter Rear
Given that the tire heights are backwards, yes. (Assuming it's a VDC car which it must be.)
I'd suggest just rotating them but it's still a bit outside of 3% ratio and if your Z is anything like others, the staggered wheel width is of no help there. I would suggest better sizes all around, 245/40 F and 275/40 R. The 265/45 is too tall and while it will work OK with that "rear tire being run up front", not optimal and may still trigger VDC error.
So many people think that going with a 35 aspect is "good". Sure, if on 19's; elsewise, stick with known stagger ratio with 40s.
Bencapasso (07-07-2024)
ou8thisSN
05-04-2012 03:08 PM
twitch579
05-28-2008 01:12 PM
yusoslo
01-11-2008 06:48 AM
partyman66
08-14-2007 06:26 PM
pss350z
05-12-2007 05:43 AM
Quick Reply: Tires
