285's on 9.5 wheel?
Old Feb 29, 2004 | 03:59 PM
silver&black03's Avatar
silver&black03
Default 285's on 9.5 wheel?
Hi everyone. I just found the wheels I am going to order. ADR M Sport. I will have 18 x 8.5 up front and 18 x 9.5 in the rear with ????
I know a lot of you have 275's in the rear and I was hoping to go a bit wider with a 285. The offset on all four wheels is 35mm. Will the 285's pose a problem? Thanks for the help. Oh I will be running Toyo T1's all around, I got a price of under $2200.00 mounted, balanced, delivered for all 4 wheels, 2 245 40 18's and 2 285 40 18's. I thought that was a great price.
Old Feb 29, 2004 | 05:06 PM
lowrider's Avatar
lowrider
285/40s fit a 9-11" wheel. 9.5" will be fine. The tires you suggest will also maintain the stagger. I would want a little more offset however, maybe +25mm front and +30mm rear.
Lou
Old Mar 1, 2004 | 08:32 AM
Type R Boy's Avatar
Type R Boy
Lou
I agree. I would worry about the +35 if there are Brembos on the car or if a big brake upgrade in planned for the future.
Old Mar 1, 2004 | 08:35 AM
ares's Avatar
ares
Veteran
I was checkin out my tires a few days ago.
285s will be fine, I think I may go up to that size if the cost isnt too much different. but more importantly, i plan to go to a 255 front. I think itll help with understeer, and it certainly looks like it could take a wee bit wider of a tire than the 245 I have.
Old Mar 1, 2004 | 08:53 AM
PoWeRtRiP's Avatar
PoWeRtRiP
be careful on those 255 up front it will probably require spacers to prevent rubbing issues on anything above 245
Old Mar 1, 2004 | 09:01 AM
ares's Avatar
ares
Veteran
my offsets are extremely safe(not really by choice, just what was available and I didnt know anybetter) I think the 255 on the 35offset would be ok as well.
I thought I remember someone running 275's in front, dont remember if he had to roll the fenders or not.
Old Mar 1, 2004 | 01:41 PM
silver&black03
I have the performance model, and don't plan on a big brake kit. So, is it safe to say the 285's will fit with no problems on my rims?
Old Mar 1, 2004 | 01:43 PM
D_Nyholm's Avatar
D_Nyholm
Well, I have some 275-40-17's in the front for autocross (offset +27) and I have no clearance problems whatsoever. There is A LOT of room in the front fenders of this car. The rears have even more clearance. I don't think that a 275 would cause a problem at all, though offset does play a part here.
Old Mar 2, 2004 | 09:01 AM
mf01's Avatar
mf01
Default Re: 285's on 9.5 wheel?
Where did you find these at? I'm looking at getting the same rims in the future. The use to go for about $800 on ebay, but I can't find them anymore.
Old Mar 2, 2004 | 10:47 AM
silver&black03
Default Re: Re: 285's on 9.5 wheel?
WWW.BIGWHEELS.NET
Old Mar 2, 2004 | 11:26 AM
mf01's Avatar
mf01
That place is pricey. Check this out http://www.thewheelconnection.com/ph...&brandsearch=1
Old Mar 3, 2004 | 05:57 AM
ttsupra94's Avatar
ttsupra94
www.autobahnwheels.com, talk to mark, he will hook you up
also, www.wheelsboutique.com
Obadabot
Jun 18, 2023 11:31 PM
Depravity
Oct 1, 2015 04:49 PM
