Need feedback on 245/40/18 front & 275/40/18 rear
Old Mar 15, 2004 | 08:43 PM
SkidMark's Avatar
SkidMark
Default Need feedback on 245/40/18 front & 275/40/18 rear
I'm strongly leaning towards getting the BBS RS-GT Diamond Black wheels, 18x8.5 front and 18x9.5 rear. I'm thinking about Sport Pilot A/S 245/40/18 front and 275/40/18 in the rear. Please give me your feedback if your running these tire sizes. Thanks!
Old Mar 16, 2004 | 09:44 AM
samlb's Avatar
samlb
Default Re: Need feedback on 245/40/18 front & 275/40/18 rear
I will let you know after I put mine on. Noticed tires were feathering plus I get that low-speed roar from the front end--going to dealer for alignment, etc. before installing new tires/wheels.
My new stuff (from Discount Tire Direct)--ENKEI RPF1 wheels 18x8.5 front/18x9.5 rear:::FALKEN GR BETA tires 245/40-18 -- 275/40-18
Old Mar 16, 2004 | 11:10 AM
MSGarrett1's Avatar
MSGarrett1
I'm installing those very same tires this week. Michelin Pilot Sport A/S (All-Seasons) 245/40 18 front and 275/40 18 rear on the Nismo wheels. Expensive Tires - $250/tire front and $320/tire rear. But from my research they should be great for dry pavement and when the roads get wet and slick.
Old Mar 16, 2004 | 11:24 AM
ares's Avatar
ares
Veteran
dont have the michelen tires, but do have tires of that size.
run fine, but I think Im going to go to a 255 in front, all other stuff the same.
Old Mar 18, 2004 | 07:39 PM
shift's Avatar
shift
The "perfectly" spec'd tire setup for 8.5"(front) & 9.5"(rear) is:
*245/40/18's on the front
*275/40/18's on the rear
Old Mar 19, 2004 | 03:27 AM
lowrider's Avatar
lowrider
I'm running 245/40/18 and 275/40/18 on my Nismos. I have Dunlop SP9000s. Great tire/wheel combo. Great Handling tire. Absolutly no issues.
Lou
Old Mar 19, 2004 | 03:43 AM
ares's Avatar
ares
Veteran
perfect setup in regaurds to diameter.
but I think the 275 looks better fit on the rim, where to me the 245 have a tiny inward slant to the sidewall as if they could be 10mm thicker. not just to have, a wider front would help to reduce understeer, which a 30mm difference front to back only makes worse than the 20mm difference it had stock.
Old Mar 19, 2004 | 12:05 PM
MSGarrett1's Avatar
MSGarrett1
The tires as I listed above are now installed. There is a noticeable increase in traction. The look from the rear is awesome, with those wide tires--kinda like a Porsche 911. In both the front and rear, the tires seem to fill out the remaining space in the wheel wells. Not sure I'd try to fit anything larger.
Old Mar 19, 2004 | 07:27 PM
SkidMark's Avatar
SkidMark
Thanks for passing on the info.
Old Mar 21, 2004 | 07:57 AM
isugoo's Avatar
isugoo
i have Goodyear F1 GS-D3 on my nismo and just love them.
tread wearing, wet track, grabbing.. i just love them.
check this site, it will give you good overview.
http://www.tirerack.com/tires/surveyresults/max.jsp
Obadabot
Jun 18, 2023 11:31 PM
sales@czp
Sep 23, 2019 03:30 PM
