THE "Bounce"
Old Mar 19, 2004 | 09:56 AM
Wotnot's Avatar
Wotnot
Default THE "Bounce"
I would like to hear feedback from owners who have solved this issue.
I'm particularty interested as I'm sure many of us are, as to which products have worked and how cost effective they were comparatively speaking.
Feel free to give your two cents.
Thanks
Old Mar 19, 2004 | 10:44 AM
bobowah's Avatar
bobowah
Default Re: THE "Bounce"
Thanks
Two things you could do..
The cheapest is order some eibach or RSR down springs.
That will solve the problem for a short period of time until the shock go bad.
Or buy the springs and koni's
You could spend the money on a nismo s-tune suspension
Or you could be baller and get some Tein Flexs (however these make squeaking noises)
Old Mar 19, 2004 | 10:47 AM
GoSooners's Avatar
GoSooners
Thanks
I have a set of brand new Tein STechs for the 350Z for sale. Never mounted.
Old Mar 19, 2004 | 11:02 AM
Sevs2k's Avatar
Sevs2k
Slapped on some eibachs. Bounce is gone.
A nice firm ride now, much more comfortable than before.
Old Mar 19, 2004 | 01:11 PM
Wotnot's Avatar
Wotnot
Default eibachs...are those springs?
Or shocks??
Old Mar 19, 2004 | 01:16 PM
GoSooners's Avatar
GoSooners
Default Re: eibachs...are those springs?
Or shocks??
Springs
jmark's Avatar
jmark
Progressive springs with a slight drop.
Old Mar 19, 2004 | 01:29 PM
The Brickyard Rat's Avatar
The Brickyard Rat
It may be abit early to get the definative answer to your question (I have the same one). I think the answer will be springs & Konis but the Konis are just starting to get onto Zs. Over the next 3-4 months we will start seeing more posts by those who have gone the Koni route.
Old Mar 19, 2004 | 03:07 PM
jmark's Avatar
jmark
Konis should start hitting the streets by months end. I have one of BJ's first 15 sets due the end of March. I intend to do the Konis and 350Evo sways. The Konis were designed & tested to work with the stock springs.
Old Mar 19, 2004 | 03:26 PM
Chicken's Avatar
Chicken
http://www.autocarparts.com/part/274/411
Did you pay about this much ($250 shipped) or is there a place that you got them from that you could recommend?
Old Mar 19, 2004 | 03:35 PM
Chicken's Avatar
Chicken
Originally posted by Apexi350z
Tein has similar drop in the front as Eibach.. even though they claim 0.7in vs 1in.
But the back Eibach is lower, visually. Get the Tein, so you don' t have to buy camber kit for the rear..
This was from another thread, but I bolded what caught my eye above, "...so you don't have to buy a camber kit for the rear." Errr... I don't know if the Tein S Techs would kill the bounce, but that's really all I want to do, not spend thousands of dollars to do so either. Tein S Techs?
Bahhh...
Old Mar 19, 2004 | 07:51 PM
Wotnot's Avatar
Wotnot
Default I've seen a few
posts about Koni shocks...I know S tune solves the problem...but its 1,260 dollars....and it shouldn't have to cost that much to get rid a an occasional bounce...
Does anyone have any idea of price?
Old Mar 19, 2004 | 07:52 PM
jmark's Avatar
jmark
BJ has a few presells left at $675 + shipping.
https://my350z.com/forum/showthread....threadid=66167
Old Mar 20, 2004 | 04:56 AM
joust75's Avatar
joust75
Default Re: Re: THE "Bounce"
I am surprised to hear such a shortsighted answer from a prominent member.
If you order a set of springs with a minimal drop then you will kill the bounce without having to worry about killing your shocks.
Go Tein S flex. .7 inch front .6 inch rear. A mild drop that wont kill your shocks and doesnt look ghetto.
BlueBatmobile has these springs and says the shocks eliminate the bounce. Not only that but he had the car alligned and the car is very close to stock specs with the drop.
Me I want durability, but Teins dont offer the handling prowess that I want and Eibachs are using a spring making process that has not been revised for years.
i am going with B + G springs, 1 inch drop all around.
No after install sag and a good rep. ZLAND has these and is happy.
PS price check says Tein S springs and B + G springs are around 150$ @ www.hopupracing.com
Old Mar 20, 2004 | 07:42 AM
Sevs2k's Avatar
Sevs2k
I bought them used.
You can get them for about $219 shipped from Jason at Performance Nissan.
The springs alone are obviously not as good as doing a full coilover set or springs + konis.
BUT, for me, the eibachs are worth every penny.
-The bounce is gone
-The car rides flatter and has less body roll
-The car takes bumps nice and firm now, but not annoying firm
-The car is more comfortable now.
-IT LOOKS GREAT
I would say buy them, I spent a lot of time reading and in the end, I just took the plunge and I love it.
Old Mar 20, 2004 | 09:06 AM
Chicken's Avatar
Chicken
Did you also have to buy a camber kit for the rear? (Or anything else?)
Old Mar 20, 2004 | 11:59 AM
Sevs2k's Avatar
Sevs2k
Nope.
I did an alignment about 5 months ago. My camber numbers at the time were:
Front left, front right (not adjustable)
-0.5, -0.8
Rear left, rear right (adjustable)
-2, -2
One week after installing the springs, I did another alignment:
-1.1, -1.5
-2.5, -2.5
Basically, the rears were adjustable down to -2.0 again but I choose to have them put to -2.5 because I didn't want to have front and rear camber numbers so close. (-1.5 vs. -2.5) I am not going to go into details on this...
Toe goes back to stock spec as its not really affected and caster number increase slightly but nothing drastic.
So, tires will wear out a little faster but it's not the end of the world. The added negative camber is great for cornering too, the front doesnt push (understeer) like it used to now.
I would definately buy these springs, if you are looking for an affordable solution to the bounce + better looks/handling and ride, this is your solution.
Old Mar 20, 2004 | 02:42 PM
Chicken's Avatar
Chicken
Sevs2k, thanks for the info and advice. One last question (I promise). What do you have to say about the above quote, specifically on the "kill your shocks" issue? I'm not looking to replace the stock shocks any time soon, this is more of a daily driver.
Just trying to decide which of these would be best (for me):
eibachs - $219 shipped from Jason @ Performance Nissan
Tein S (.7 inch front .6 inch rear) - 150$ @ hopupracing
Espelir (20/30mm drop, in theory) ~ same price as Tein though used
Old Mar 20, 2004 | 04:38 PM
Sevs2k's Avatar
Sevs2k
On cars like ours, the shocks are already good quality, installing springs that increase spring rate by less than 10-15% will not lead to the shocks being "killed" quickly. The major factor is the engineered working range of the shocks, the stock shocks are made to work at a certain height, changing that height will lead to more wear on the shocks. BUT a 1 inch lowering isn't really a major change.
This is more of an issue for people with civics, Golfs... Who have lower quality shocks from the factory and they drop 2-3 inches on them.
It all depends on the way you drive and your local streets, but you can expect your shock life to be about 75%-90% of what it would have been with stock springs. So if it was going to last 50k miles, it will last about 40k miles now.
As for which springs, I got the eibachs and am very happy, I was thinking ot the S-Techs but I am happy I didn't get them now. The drop won't be visible with those and they are actually softer than stock.
Go eibach and you won't regret it.
Old Mar 20, 2004 | 05:14 PM
Chicken's Avatar
Chicken
OK, I'll take your suggestion and go with it. Hopefully it will look OK even though I merely have the stock 17" wheels.
Pity, if they are $219 shipped, I wonder how much they would be picked up. A bunch was heading up to Performance Nissan today DOH! I have been feeling a bit under the weather or I might have gone.
