spacers *pics*
Old Mar 30, 2004 | 08:26 AM
NY 350Z's Avatar
NY 350Z
Default spacers *pics*
had some old spacers lieing around...so i decided to see if they fit. Well they did and i took some pics. i tried to take the pictures at good angles so you can see the differences. hope you can tell. They are 1/4 inch spacers and i had no problems with stock studs and lugs, i got a good couple turns out of the lug wrench and they tightened nicely. took it for a test drive to only about 65 mph and i had no vibrations. any questions just ask.
pic 1- has no spacer
pic 2- has a spacer
pic 3- you can see the spacer
pic 4 + 5- is the spacer itself
pic 6- spacer on left wheel,no spacer on right wheel
Old Mar 30, 2004 | 08:27 AM
NY 350Z's Avatar
NY 350Z
Old Mar 30, 2004 | 08:28 AM
NY 350Z's Avatar
NY 350Z
Old Mar 30, 2004 | 08:29 AM
NY 350Z's Avatar
NY 350Z
Old Mar 30, 2004 | 08:30 AM
NY 350Z's Avatar
NY 350Z
NY 350Z's Avatar
NY 350Z
Old Mar 30, 2004 | 08:31 AM
NY 350Z's Avatar
NY 350Z
Old Mar 31, 2004 | 12:18 PM
overboostedtoy's Avatar
overboostedtoy
do you feel the difference on handling? w and w/o the spacer?
Old Mar 31, 2004 | 12:45 PM
NY 350Z's Avatar
NY 350Z
i havent took it on tight turns or anything yet and it doesnt look like i will till sunday,its supposed to rain everyday till then, so the Z stays in the garage.
but i couldnt imagine that 1/4 inch spacers would make a big enough difference,i could be wrong.
Old Mar 31, 2004 | 04:10 PM
joust75's Avatar
joust75
These spacers lessen the amount of contact that the bolt has with the nut... Couldnt this possibly weaken the bolt and cause a wheel to fly off or something?
Old Mar 31, 2004 | 04:52 PM
NY 350Z's Avatar
NY 350Z
nope,like i mentioned before, i got a good amount of turns on the lug wrench that i definetly knew it was on and then i got it nice and tight. when it gets ncie out again im gonna drive aroudn and then go around with the wrench and see if any loosened. Thats a good question tho cause i was wondering that myself before i put them on.
Old Mar 31, 2004 | 10:26 PM
pixelninja's Avatar
pixelninja
non hub centric spacers.... booooooo.
When you pick up a nasty vibration above 40mph you'll know what its from.
Old Apr 1, 2004 | 03:37 AM
NY 350Z's Avatar
NY 350Z
first post i typed "took it for a test drive to only about 65 mph and i had no vibrations"
Old Apr 1, 2004 | 10:34 PM
350ed's Avatar
350ed
Professional
How many turns did you have? I think 8 turns is recommended!
Old Apr 1, 2004 | 11:31 PM
joust75's Avatar
joust75
Good question... Survey says: ?
Old Apr 2, 2004 | 03:30 AM
NY 350Z's Avatar
NY 350Z
around there but i WILL take a lug off later after work and post!
FromGtoZ
Sep 20, 2015 03:41 PM
torchkc
Sep 11, 2015 08:26 PM
