What PSI for Toyo T1-S tires?
Originally posted by gunnerz
What is the recommended PSI for everyday use on these tires?(245/35R19 and 275/35R19)
Cheers Amy
Originally posted by wick3d350Z
wouldnt you use the nissan specs still?
Keep the TPS senders.
Cheers Amy
If you are running larger than the OE size, usually you can bump the psi up a couple. For instance I am running 245-40-18 at 37 and the OE 245/35/17 were 34 & 32 (02 Audi Avant). Questions, e-mail me at youngc@toyotires.com.....I am not on the board that often so e-mail might be better.
Man, I was running mine with too little air I guess. I was around 34, maybe I will step it up a bit whenever I can get my rims back (sigh) and put the Toyos back on. I am worried that they would be too rough and bouncy at 37 psi though, cause the Z has a tendency to be bouncy anyway.
I have the same set up. I run about 35-36 in the winter. In the summer I start at about 34-35 because once I drive a little the pressure goes to about 36-38. Only a little difference in the ride, not to obvious. So far tire wear is pretty even at 7000k miles.
