spinning
Old Apr 13, 2004 | 05:56 PM
maxi_z's Avatar
maxi_z
Default spinning
I noticed that when the rear wheels are spinning at not too high rpm in 1st or 2nd gear on the wet, without traction control the rear suspension is bouncing and the spinning of the wheels is not smooth, it do not do it as much if you go at high rpm.
I've been told that it's because tha standard suspension are not too stiff, and it would not do that with stiffer ones.
Does your z do that too if you spin the wheels?
Old Apr 13, 2004 | 07:04 PM
sschmuve's Avatar
sschmuve
Yes...they all have wheel hop.
Old Apr 15, 2004 | 05:31 AM
samlb's Avatar
samlb
Default Re: spinning
Be careful with wheel hop--that violent motion can break suspension parts. You'd better get off the pedal guick when you go into wheel hop. If you're good just tap the clutch to allow RPM's to increase -- then get back into it hard. Feather the throttle to control wheel spin.
Does anyone know of mod that will eliminate wheel hop?
Old Apr 15, 2004 | 03:47 PM
Jetpilot718's Avatar
Jetpilot718
Default Re: Re: spinning
Yeah, Greddy and Stillen makes a mod that will eliminate wheel hop... they make the car sound funny too
Old Apr 15, 2004 | 11:00 PM
maxi_z's Avatar
maxi_z
Would just aftermarket springs avoid wheel hop?
Old May 1, 2004 | 09:56 AM
maxi_z's Avatar
maxi_z
BTT
MAsSIVrOOM
Oct 20, 2023 10:50 AM
Calinismo350z
Sep 14, 2015 04:04 PM
Suffolk350z
Sep 13, 2015 02:43 PM
fst100
North East
Sep 8, 2015 11:37 AM
droideka
Jan 12, 2003 07:23 AM
