20" rim help
Old Apr 16, 2004 | 08:09 AM
fresno350's Avatar
fresno350
Question 20" rim help
i want to get 20" rims.....20x9 and 20X10. can i put them on my performance Z? i dont have brembo brakes. will there be any modifications that have to be done? what size should i get as far as offset and all that? how will it affect the ride and what about the tire pressure sensors? thanks for your help
Old Apr 16, 2004 | 10:02 AM
Vlad's Avatar
Vlad
Go for 21" and you can save a lot on tires since you won't need any .
Old Apr 16, 2004 | 11:01 AM
OffdeeZ's Avatar
OffdeeZ
____________________________________________________
Need another drink of Hateraide?
Old Apr 16, 2004 | 11:04 AM
OffdeeZ's Avatar
OffdeeZ
20's look a bit large but still cool. Fresno 350, look into 19's I think you will like the look and the offsets and tire sizes will be easier to come by, just by searching the forums. Look at the tire size calculator to see what tires will fit without messing up the speedometer with a larger than stock wheel.
Old Apr 16, 2004 | 01:37 PM
fresno350's Avatar
fresno350
ok i will check into the 19's. thanks alot for your help! Vlad, wow those 17's are the BOMB. you can probably get those at pep boys right?
Old Apr 16, 2004 | 01:59 PM
OffdeeZ's Avatar
OffdeeZ
a guy who's small (17) always is jealous of someone with a few more inches! Go 19's 8.5 front 9.5 rear with anywhere from +22 to +35 offset and your wheels will look cool! Good Luck Fresno!
Old Apr 16, 2004 | 06:24 PM
havabooz's Avatar
havabooz
the guy wants 20" wheels...he doesnt want ppl to tell him to get 19's
anyhow...you wont need any modification if you get the correct offsets
PM ACP cause he has 20's on his car...im not sure about tps cause i never had it but im sure it can be worked out
if the roads werent so bad in NY i would get 20's..im prob better off with 18's...all the power to u if you can drive around with 20's as long as they arnt chrome
Old Apr 16, 2004 | 10:06 PM
KarmaMag's Avatar
KarmaMag
You can go as wide as 9.5" in the front and 11" in the back with no modification. With 11", you can run 305/25-20.
Old Apr 19, 2004 | 09:42 PM
fresno350's Avatar
fresno350
thanks everyone for your help!
Rev_Night
Nov 7, 2020 06:00 PM
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
