Anybody running 255 front & 285 rear?
Old May 8, 2004 | 03:14 PM
moog's Avatar
moog
Default Anybody running 255 front & 285 rear?
I'm wanting to run these slightly wider sizes than the normal 245/275 everyone else usually runs. If I do drop my car it will be 1" max. Any feedback on if this would cause problems?
Old May 8, 2004 | 08:32 PM
KarmaMag's Avatar
KarmaMag
I don't think you'll have any problem. I'm running 255/295 and never have a single problem. I install 245/275, 245/285, 265/295 on my customer cars and never have any problem with them.
Old May 8, 2004 | 08:43 PM
KingWazir's Avatar
KingWazir
That's what I'm running. No problems with +26 offset in front, +29 in rear. 285/30 in rear, 255/35 in front. I just wish I went 295 or 305 in the rear.
Old May 9, 2004 | 06:05 AM
zillinois's Avatar
zillinois
265/35 front
295/35 rear
1" drop and camber needs adjustment, but no rubbing. Offset 25 front, 30 rear.
Old May 9, 2004 | 06:15 AM
moog's Avatar
moog
Hmmm thanks for the input guys. I'm just concerned, since I'll be running 20" wheels. I was thinking that extra bit of wheel diameter might cause a problem because most of you are running 18's or 19's w/ those wider tires.
Old May 9, 2004 | 06:23 AM
zillinois's Avatar
zillinois
If you keep the overall tire diameter approximately the same, with a lower profile tire, you should be alright.
Old May 9, 2004 | 06:50 AM
moog's Avatar
moog
Yeah, I'm checking out that tire dimensions calculator on the Discount Tire website right now.
Old May 9, 2004 | 07:06 AM
zillinois's Avatar
zillinois
Should have read your sig I guess. ;-) Those Iforged are sweet. But 20" tires are going to be some bucks!
Old May 9, 2004 | 07:10 AM
Javi's Avatar
Javi
I'm using that exact setup in 19's and +22 on all 4 sides. Stock suspension, no rubbing issues. You can check the pictures at:
http://www.imagestation.com/album/?id=4286950317
or the thread:
https://my350z.com/forum/showthread....threadid=73742
I WILL go with 295's as soon as my rears need changing...
Old May 9, 2004 | 02:58 PM
Jsn350Z's Avatar
Jsn350Z
I think the problem would be finding the tire of your choice in 285/35/19. Other then that there should be no problems. Also, I am going with a 255 in the front next time around as well.
Old May 9, 2004 | 08:32 PM
moog's Avatar
moog
I'm looking for 20" tire choices.
hulkout
Apr 28, 2017 09:00 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
samansharif
Sep 25, 2015 12:31 PM
