Volk whells and Tire pressure sensor
Is there a problem to mount the tire pressure censors when changing to Volk wheels. Will the sensor mount on the new valve stem - if that's where it goes.
I think I've seen a couple of posts on this subject - can someone refresh
I've just done it on the TE-37's and no problems at all.
But this is different depending on which volk wheels you get. I believe it depends on the type of construction (i.e. reversed lip etc. since that changes the structure on the inner wall of the valve stem)
Just be careful if you're going for larger wheels (i.e. from 18s to 19s especially). The lower profile tires you'll need may not provide enough room for the sensors and you could break them.
