drilled rotor question. Please help
if i purchase the drilled rotors.... will they crack if i do 1/4mi runs and freeway runs and hard stopping occasionally. Under what conditions will drilled rotors crack?
eric... you won't have anything to worry about... you won't be getting the brakes hot enough or stressing the rotors enough to induce cracking... enjoy the look of your drilled rotors
u4ia... for track events you should avoid cross-drilled rotors... you will be heating them up and stressing them enough to crack them. Slotted are a better alternative, offer good outgassing and almost never crack
Hope that helps,
PeteH
Hope that helps,
PeteH
you always have a chance of drilled rotors cracking, but a few track events from time to time probably won't hurt them... now, one track event a month where you are really cooking the brakes, that WILL kill the rotors!
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
