Slip Indicator
Old Jul 21, 2004 | 07:28 PM
midsouthps's Avatar
midsouthps
Default Slip Indicator
Just took my Z in for first service. On my way home, when accelerating hard in 4th gear, the slip indicator came on and killed power. Straight, dry road. It didn't happen on the shift to 4th. It was about mid way throught the RPM range. It happened 3 different times. What's going on???
Old Jul 21, 2004 | 08:26 PM
funkdamonkman's Avatar
funkdamonkman
Make sure that the 225 tires are on the front and the 235 tires are on the back. My dealer accidentally put 235s in the front and back (long story) and it caused the same problem.
Old Jul 22, 2004 | 01:38 PM
Dissident's Avatar
Dissident
Mine does that crap all the time. Never found a solution, and obviously (cause of the speed) dealer cannot replicate. grrr.
Old Jul 22, 2004 | 02:24 PM
myz8a4re's Avatar
myz8a4re
turn the vdc off & you wont detect slip.........
-justin
Old Jul 22, 2004 | 08:41 PM
midsouthps's Avatar
midsouthps
I know I can turn off traction control and eliminate the symptoms. I'm more concerned with what is causing it. Tires and wheels are stock and this happens on straight dry pavement in 4th gear. There is no actual slipping occurring. Is something in the electrical system (ECU) screwed up? Have I got some crossover in the wiring?
Old Jul 23, 2004 | 04:31 AM
Balls's Avatar
Balls
sounds like you got the wrong sized tires homie... if the overall size of your wheel+tire is too small, the car will think that the wheels are spinning...
tell us the wheel and tire dimensions...
Old Jul 23, 2004 | 05:00 AM
Balls's Avatar
Balls
uh... just read your last post....
you have stock wheels and tires???? oops then?
I'm changing my answer then.... I think funkdamonkman's suggestion is most likely.
loudtoyz
Apr 6, 2023 04:52 AM
aarrgghh
May 1, 2022 11:04 AM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
Depravity
Oct 1, 2015 04:49 PM
hardwood66
Sep 8, 2015 04:31 AM
