Help.. Caliper won't go back on rotor??
Old Jul 22, 2004 | 03:16 PM
dskang100's Avatar
dskang100
Smile Help.. Caliper won't go back on rotor??
Well I was with my friend yesterday trying to put in some Hawk HPS pads... did the rear took the wheel off took the caliper off took the old pads off and put the hawk ones in place but basically the hawk HPS pads are too big?? I highly doubt it's the pad.. my friend thinks it's my brake lines that are stretched out and that's why it doesn't fit over the rotor with the Hawk Pads... anyone got any advice please? Thanks.
Old Jul 22, 2004 | 03:30 PM
J Ritt's Avatar
J Ritt
The box for the proper HPS for the rear of the non-track 350Z should read HB370 F.559. That will tell you if you have the wrong pad. Start there. The pad should drop into the caliper with a little wiggling.
I'm not sure I understand the rest of your problem. Your line should have nothing to do with your pad not fitting in the caliper.
Did you use a C Clamp to push the pistons back into the caliper before you tried installing the pads? If not, that's the problem. If the pistons are extended, they will be squeezed to close together to fit over the rotor. Do a search. Someone on this board just did a great install write up on pads that you should check out. If you still don't have an answer, let me know.
Old Jul 22, 2004 | 03:39 PM
wren57's Avatar
wren57
Yeah, I bet its the c-clamp. You need to clamp the piston to the other side of the caliper and push the piston down as the piston adapts to the thinner pads.
Old Jul 22, 2004 | 05:40 PM
dskang100's Avatar
dskang100
Ohhh.. we didn't use any C clamps just our fingers, lol...
Old Jul 23, 2004 | 01:40 AM
Tigerstylez's Avatar
Tigerstylez
open the bleeder on the caliper. Its has a rubber piece over the top of it. Remove it and gently unlock the bolt. Then use your clamp to squeeze down the inside of the brake piston. Be sure and retighten the bleeder screw, or you will have a big a@@ mess...
Old Jul 23, 2004 | 04:28 AM
Balls's Avatar
Balls
I'd be a little worried about air bubbles or making "a bid a@@ mess" doing it that way. Just use a c-clamp. It's not that hard.
On a side note... I've done it with my bare hands before and it took for-EV-er... haha.
Old Jul 23, 2004 | 06:30 AM
350zroadster's Avatar
350zroadster
can't.... take.... eyes.... off.... signature....
wait, what is this thread about?
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Stevo Z
Oct 3, 2015 09:14 PM
Depravity
Oct 1, 2015 04:49 PM
samansharif
Sep 25, 2015 12:31 PM
