350Z on 17" RPF1's at SoCAL Costa Mesa Subi Show...
Jason... for the track I use 17x9 ET35 Enkei RPO2J with 275/40-17 Yokohama AO32R all around. I have the car lowered with Eibach springs and I never have issues with tire rubbing. If you are gonna run a wide tire, might as well go all out! Besides, the extra tread width in the front helps reduce understeer.
Cheers,
PeteH
Cheers,
PeteH
Originally posted by daytona350z
oops, forgot to ask jason, will these clear my brembos?
Peace
Performance Nissan
Performance Nissan
NUFF - I didnt forget about you... they will be in some time this week enkei is telling me
I believe they will clear brembo's... the rear no question about it... but the front... you MAY need a 5-15mm spacer... the offset on the front is 30mm which is not to hot... A 17x8.5 +18mm offset would have looked MUCH better...
These will fit over stop tech 13's with the offset on my car...
I am currently running stock brakes with upgraded stop tech aero rotors and nismo brake pads... I am planning on going to the 13" stop tech front and 12.8" rear kit as soon as I can afford it
Performance Nissan
Performance Nissan
oh NICE! I wasnt sure if 17x9 would fit up front with the 275... hrmm... if i can im gonna try for 275 in front and 285 in the rear...
what offsets are you running?
PeteH
Jason, I'm running 275/285, 40/17's on RPF-1's. Fronts are 17X9"/35mm rears are 17X91/2"/38mm. No rub ever, no clearance problems. I am running RS*R springs with Koni's.
The inside on the front only have about a pencil witdh of clearance from the sidewall of the tire to the upright. Rears have tons of room.
liqalu04
Jan 2, 2022 12:58 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
