F_A_T_T_E_S_T Tires on a 19" rim...????????
Old Feb 24, 2007 | 10:29 AM
  #161
emulzhn's Avatar
emulzhn
I just got back from a local shop to inquire about tire size, offsets and so forth. I told him that I was interested in volk GTC 19"/10.5 to use with 295's. He called his supplier buddy out in Cali to see on GTC's availibitly and tire combination. His budd claims that I'll only be able to use 285/30/19 for the 10.5 without rolling the fenders. He states he does not approve of fender rolling as cutting (rolling) the inner edges deteriorates the shape of the fender. He claims that he doesn't know of anyone in our local area (south jersy/ Phila) who does this b/c of this reason.
my quest: is this true as the fronts are already done this way. Also, should I press to look for a fender roller to push for 295/35/19 or greater or just settle for 285/30/19 and just be overly cautious with road imperfections
Old Feb 24, 2007 | 10:37 AM
  #162
OffsetZ33's Avatar
OffsetZ33
find another shop who knows what they are talking about...
Old Feb 24, 2007 | 12:47 PM
  #163
rkd350z's Avatar
rkd350z
interesting..
Old Feb 24, 2007 | 01:15 PM
  #164
MiniRide's Avatar
MiniRide
I kno.. I am rocking 295/35/19 with volks.. and I needed to cut my inner fender..
Old Jun 13, 2007 | 11:39 AM
  #165
mlam002's Avatar
mlam002
sorry for bringing up an old thread..
but here are the current specs for my wheel/tire set up
Volk CE28N, 19x8.5 front, 19x9.5 rear
currently running Yokohama AVS Sport tires 265/30/19 front, with 295/35/19 rear..
All stock suspension and I do not intend on lowering or modifying the suspension in any way.
I bought the wheels that came with these brand new tires, so i didn't complain about the sizing, which may or may not be the right and ideal set up.
I'm currently in the market for new tires and would like this boards opinion on the set up I have chosen.
I'm looking on running 265/35/19 front and 295/35/19 in the rear... could I possibly run a 305/ tire in the rear? Anyone have an opinion on a better tire size reco? I'm looking to run the widest thickest tires possible.
I do not know much about tires nor how that affects oversteer understeer..but like i said I would like to run the thickest widest tires possible while still maintaining a balanced and fully functional vehicle ( i do not want ABS/traction etc. issues)
thanks!
Old Jun 13, 2007 | 01:03 PM
  #166
redlude97's Avatar
redlude97
thanks!
295 on a 9.5 is already outside of the "safe" range suggested by the manufacturer, 305 should be out of the question. Get some 10.5's if you want to run a 305. The bulge in the sidewalls will hinder performance more than help it in this case
Old Jun 13, 2007 | 01:16 PM
  #167
JDMFairladyZ33's Avatar
JDMFairladyZ33
+1 with your current wheel setup you need to run 245/35/19s and 275/35/19s
Old Jul 12, 2007 | 08:35 AM
  #168
Gman2004's Avatar
Gman2004
Default My set up
19 x 9.5 265/35/19
19 x 10.5 295/30/19
Stock height and rear fenders rolled. Tein Flex is going on the car soon.
Old Jul 12, 2007 | 08:38 AM
  #169
Alberto's Avatar
Alberto
Cranky FI Owner
Originally Posted by Gman2004
19 x 9.5 265/35/19
19 x 10.5 295/30/19
What offsets?
Old Jul 12, 2007 | 08:41 AM
  #170
Gman2004's Avatar
Gman2004
Originally Posted by Alberto
What offsets?
Volk GT-7
19 x 9.5 +30
19 X 10.5 +24
Rolling on PS2's
Old Jul 12, 2007 | 08:54 AM
  #171
Gman2004's Avatar
Gman2004
I posted the wrong offsets. I edited my previous post.
Old Jul 12, 2007 | 03:57 PM
  #172
Gman2004's Avatar
Gman2004
Default pics
I just got the tires today. They fit pretty well although after I install the coilovers it looks like I may have to cut the rear fenders. The front fenders look like they probably won't need to be rolled or cut.
Old Jul 16, 2007 | 11:21 AM
  #173
Alberto's Avatar
Alberto
Cranky FI Owner
^^Roll your fender Gman, should be no more than $100, I just did a G coupe here in MD that was running 295/35 on a +22 10.5" rim...
I have my fenders rolled, and currently run 285/35 19 on a 19 X 10.5" +22 with NO issues (and I just raised my car some) I was gonna do 305/30 19 but tirerack will not let me test drive the tire, only mount them and put it on the car-which is no test. Im afraid it will rub, so I'll likely only do a 295/35 on my next set-up. I remember seeing many tires in those sizes after searching tirerack and discounttire I can only find KDW2's...
Old Jul 16, 2007 | 11:42 AM
  #174
synth19's Avatar
synth19
What is the max tire width one can go on a 19x9 wheel? 265?
Old Jul 16, 2007 | 12:30 PM
  #175
Alberto's Avatar
Alberto
Cranky FI Owner
275 EASY with no to minimal pudge...
Old Jul 17, 2007 | 09:44 AM
  #176
DatukZ's Avatar
DatukZ
Originally Posted by Jsn350Z
Your sizes are wrong as pointed out above. The correct profile to get with a 19 inch wheel is 35. There are people who have gone wth a 30, and most of them have problems. I will give you that SOME have gone problem free. The 30 profile is correct for a 20 inch wheel on the Z.
AGreed.
Old Jul 18, 2007 | 05:01 PM
  #177
Chad68's Avatar
Chad68
245/35/19's front on a 20 offset
305/30/19 rear with a 35 offset.
Had to mod the fender lip a tiny bit. Lowered almost 1.5" rear and about 1" front.
Old Aug 15, 2007 | 09:48 AM
  #178
Zquicksilver's Avatar
Zquicksilver
^ Nice setup... I stumbled accross this thread while searching for something else. Nice to see its alive, lol!
For those looking for balance, ie much less understeer from staggered setups and a suspension drop, I would suggest the following.
-Set your rear camber to around 1' degree and leave the front around 1.5-2' degrees. (I have the SPC camber kit)
-If you have sways, set the front to soft and rear to medium, or set the front to medium and rear to firm. (I went with Hotchkis)
-If your going to to get downsprings, get a set with a higher compression setting in rear vs front. (I went with RS*Rs downsprings)
The suggestion above will force the front tires to bite harder and with more authority. You'll get more life out of your rear tires, plus better traction off the line!
This is what my Z currently looks like, you can see that there is more camber in front than rear.
Zquicksilver
Old Aug 15, 2007 | 03:24 PM
  #179
Ken@Performance's Avatar
Ken@Performance
Performance Nissan
Front - 19x9.5 +30 w/ 275/30/19
Rear - 19x11 + 24 w/ 305/30/19
Lowered about a inch and rolled the fender.
Old Aug 15, 2007 | 04:01 PM
  #180
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Ordered a set of iForged wheels a couple weeks ago: 19 x 9.5 and 19 x 11. I wasn't told what the offsets would be, but I will need to roll my rear fenders. I'll be running PS2's with 255/35's in front and 305/30's in back. I'll post up some pics once I get them installed.
