Any way to shut off the tire pressure warning beep?
Old Aug 16, 2004 | 08:33 PM
vice86's Avatar
vice86
Default Any way to shut off the tire pressure warning beep?
I had performance nissan mount the new rear tires on the powdercoated rims they sent me WITHOUT the TPS in them and now its always beeping...I was gonna put them back in on my next set of rear tires. Is there any way to shut off that annoying beeping sound that goes off when i start my car and every so often while driving?
Old Aug 16, 2004 | 10:06 PM
AmyCroft's Avatar
AmyCroft
Default Re: Any way to shut off the tire pressure warning beep?
Pull the cable from the TPS reciever - under passenger dash - right above where the passenger feet would be.
Reboot ECU
Better yet remove TPS reciever and antenna and send it to me..
Actually the service manual (CD) has copious notes on the TPS
Cheers Amy -
Old Aug 17, 2004 | 05:14 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
That brings up an interesting question. Every once in awhile, my TPS will malfunction and not get a signal. In other words, if I bring up the tire pressure window on the multi-function gauge pod, it reads: _ _ _ _ on one tire and say 34 on the other. Also, on occasion, the tire pressure warning light on the dash will come on. I get no beep however.
If you get aftermarket wheels/tires and don't have the TPS in them, will your warning light for the dash always be on? Will pulling this cable turn it off?
Thanks
Old Aug 17, 2004 | 05:24 AM
DrDrilZ's Avatar
DrDrilZ
i have aftermarket rims without the sensors in them. my dash gauge reads ---- on all tires. i hear no audible warnings at all and my light in the dash only comes on after driving about 45 minutes. i dont know why it behaves this way, but i can deal with it.
Old Aug 17, 2004 | 05:44 AM
vice86's Avatar
vice86
Default Re: Re: Any way to shut off the tire pressure warning beep?
Reboot ECU
Cheers Amy -
THanks for the info...although I never got a CD with my Z...hhhmmmm.
Old Aug 17, 2004 | 06:10 AM
teh215's Avatar
teh215
Default Re: Re: Re: Any way to shut off the tire pressure warning beep?
You have to buy the Service Manual or find some place online to download it. It doesn't come with the car.
Old Aug 17, 2004 | 06:48 AM
vice86's Avatar
vice86
ok..thanks teh.
Old Aug 17, 2004 | 07:04 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
So everyone without the TPS in their aftermarket wheels has to deal with the little yellow light on their dash after 45 minutes of driving?
This is an OUTRAGE!!!! j/k
But seriously, does everyone else with this setup get the same thing?
Old Aug 17, 2004 | 03:25 PM
fresno350's Avatar
fresno350
bonz,
i unpluged my tps reciever after putting aftermarket wheels on. you still get the light, but no audible warning, and your pressure reads nothing. its no big deal to me.
Old Aug 17, 2004 | 08:16 PM
AmyCroft's Avatar
AmyCroft
Default Doctor ? Batteries ?
Hello Doctor
Do these TPS transmitters have batteries?
Amy
Old Aug 18, 2004 | 04:27 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Good question. I have no idea. I would guess that they would have to have them right? I mean, they aren't wired in any way are they?
Old Aug 18, 2004 | 06:18 PM
Jaki's Avatar
Jaki
My light and beeping noice went on today and it reads 28 and sometimes it just reads ----- what is the pressure I should have on it so this turns off?
I don't have the manual to look it up...
Old Aug 18, 2004 | 07:11 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
32-34 psi
Old Aug 20, 2004 | 02:55 PM
ChinaClipper's Avatar
ChinaClipper
Default Re: Batteries in TPS?
Hello Doctor
Amy
Amy & Dr Bonz,
TPS has permanently installed batteries. They are activated by a centrifugal switch that closes when you drive faster than about 30-35 mph. The TPS manufacturer says that the battery "under normal driving conditions" (whatever THAT means!) will last 7 years. New TPS sensors must then be purchased when batteries die - hence warning light indicating system failure! [YIKES!!!]
Without TPS sensors installed, your onboard TPMS receiver measures no signal received and hence displays the "---" on the display. After a period of constant "---", the 'annoying' yellow warning icon lights up in the gage pod. Hey guys! There's a market for a new 350Z product: I can go to Office Depot and buy a package of Avery black, self adhesive little round dots. Market them for $3.50 (get it?! ) apiece on the vendor board as a cure for the dreaded YELLOW TIRE ICON LIGHT! Apply sticker directly over gage display when lit.....
What do you guys think?
Old Aug 21, 2004 | 07:16 AM
Reaper700's Avatar
Reaper700
Jason at Performance Nissan advised me that after several power cycles with out the TPS sensors the alarms will stop ?
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
