Does anyone have 255/40/18 in front?
Old Aug 18, 2004 | 03:11 PM
Yellow Stealth's Avatar
Yellow Stealth
Question Does anyone have 255/40/18 in front?
I have done a search, but could not find an answer for my specific setup.
I have new 18" wheels coming in:
Front 8.5" > offset=35
Rear 9.5" > offset=35
I am not changing my suspension, but I would like to go with wider tires.
Since I do not want my speedometer or VDC affected, the perfect size to maintain the exact same diameter (according the the tire calculator at http://www.miata.net/garage/tirecalc.html) is:
255/40/18 front
275/40/18 rear
I know the rear has been done before. I could not find anyone who had 255/40/18 in the front though.
Is anyone running that size in front? Will it fit?
Old Aug 24, 2004 | 12:07 PM
Yellow Stealth
Come on, nobody has ever tried 255/40/18 in the front?
Old Aug 24, 2004 | 12:12 PM
ElvishasaZ's Avatar
ElvishasaZ
dude people have even put 275's in the front. 255 is not a problem.
Old Aug 24, 2004 | 09:13 PM
Rampant's Avatar
Rampant
275s with a +30 offset upfront has been proven to work, so with your 5mm offset difference, you still should have enough room for 255s, even 265s.
Old Aug 25, 2004 | 10:34 AM
Yellow Stealth
Thanks for the feedback. If you want to see the unmounted rims, take a look at my other thread:
https://my350z.com/forum/showthread....threadid=88725
Old Aug 26, 2004 | 10:14 AM
mrZ's Avatar
mrZ
your vdc will be screwed up. tire dia must stay the same or as close to stock as possible.
Old Aug 26, 2004 | 10:21 AM
Yellow Stealth
If you check the first link I posted to the tire calculator, you will see that I specifically picked that size because they would be EXACTLY the same diameter as the stock 225/45/18.
Old Aug 26, 2004 | 11:07 AM
KShep's Avatar
KShep
Running 265/35/18 on the front +23 and no SLIP light.
Old Aug 28, 2004 | 09:50 AM
350z4steve's Avatar
350z4steve
you have a nice tire size combo in front and rear . Do you have any pics of your ride to post?
Old Aug 28, 2004 | 07:29 PM
PhoenixINX's Avatar
PhoenixINX
Wrong.
Obadabot
Jun 18, 2023 11:31 PM
Justin100
Nov 25, 2021 06:26 AM
