How LOW can it be?
Old Sep 16, 2004 | 06:32 AM
lemonjihwan's Avatar
lemonjihwan
Default How LOW can it be?
i just have real quick question..
if i get a new spring to lower my Z,
how low can i go with stock parts?
im trying to get JUST a spring..
I will be really happy if i can lower..just an inch..
and also..what kind of spring should i use?
best one???
I just have no clue.. sorry...
need some advice
Thanks
Old Sep 16, 2004 | 09:31 AM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
I think the Eibachs lower an inch. You can do this on stock parts, your alignment will be off. How much depends on what your alignment specs are now.
Old Sep 16, 2004 | 10:02 AM
LATEZ's Avatar
LATEZ
heres my on eibachs
1" drop camber is nasty on the rear wheels ..stock wheels shouldn't be so bad
Old Sep 16, 2004 | 10:42 AM
LATEZ's Avatar
LATEZ
side view
Old Sep 16, 2004 | 12:11 PM
tylerdurden's Avatar
tylerdurden
I have Eibach's on stock shocks. The drop is nice. Bad camber like everyone else. Looks real good though!
Old Sep 16, 2004 | 04:15 PM
maxipad96's Avatar
maxipad96
Heres my camber printout after eibachs
Old Sep 16, 2004 | 05:14 PM
lemonjihwan
bad camber?? so no camber kit..
what happened to you all??? messed up tire or..
i just wanna learn.. help!
by the way!! thanks for all the replies..!!
Old Sep 16, 2004 | 07:00 PM
maxipad96's Avatar
maxipad96
They were able to pull mine nearly in spec. The top reading is after the spring install when the camber was WAY out of spec. The bottom reading is after the alignment was done. Basically 3/4 are in spec. The fronts are the best. And the rears are almost in spec. Fronts should wear fine. The rears should wear a little on the inside. Nothing major though.
Old Sep 16, 2004 | 08:22 PM
Moroccan_Mole's Avatar
Moroccan_Mole
negative camber isn't bad ... it provides great mechanical grip in the corners ... it just eats tires a little fast ... im running -3.5 negative camber right now because my car is so low
Old Sep 18, 2004 | 05:51 PM
lemonjihwan
so basically i can just goahead and get a spring and.. lower my car about an inch right? and ill be fine with it.. without any major problem..
and also... where do I go to get my car lowered??
anybody shop will do ??? or ....
Old Sep 18, 2004 | 11:33 PM
HipHopPro's Avatar
HipHopPro
LATEZ,
What wheel is that, and what's the size?
I'll like to get them for my G35 Coupe. It look's like BBS wheels.
Old Sep 20, 2004 | 09:29 AM
LATEZ's Avatar
LATEZ
work termist tm1
heres a pic from their site
19x8.5 and 19x10
Old Sep 20, 2004 | 09:38 AM
LATEZ's Avatar
LATEZ
thats from My car not their site ...sorry
heres link
http://www.work-wheels.co.jp/wheels/home.html
Old Sep 20, 2004 | 10:04 AM
Vivid Racing
Vivid Racing
Just about any shop should be able to do it. If you know anyone with any mechanic skills at all you could do it yourself. It is very simple on this car to change the springs.
Old Sep 20, 2004 | 11:44 AM
mofoz's Avatar
mofoz
Tanabe have great springs as well, with a drop of about 1.5inches. Every that sees my car thinks it looks awesome with the drop. My camber is barely outta spec.
Old Sep 20, 2004 | 01:12 PM
HipHopPro's Avatar
HipHopPro
LATEZ,
Thanx for the info on the wheels.
Old Sep 20, 2004 | 05:30 PM
lemonjihwan
mofoz :
with a tanabe spring.. 1.5drop..
do you have any problem driving around???
speedbumps or nothing???
Old Sep 20, 2004 | 09:35 PM
GQ 350z's Avatar
GQ 350z
mofoz, please more pics of your ride... i just bought the gf210 but i'm worried that its too low...your impressions are much appreciated!
Old Sep 21, 2004 | 05:26 AM
mofoz's Avatar
mofoz
i havent scraped my bumber or sides yet(*crosses fingers*) but i did scrape the plastic under piece a couple times. But they were severe inclines that i could have taken better.
Here are some pics, these are right after i installed them, so they probably settled a bit more. You know its lower when you drop the car with the jack, and you cant get the jack out
Before
After Being Lowered.
Old Sep 21, 2004 | 07:53 AM
lemonjihwan
looks damn nice...
