What kinda rims are these?
Old Sep 28, 2004 | 11:46 AM
BOZ23's Avatar
BOZ23
Default What kinda rims are these?
I've never seen this rim. at first, I thought they were either giovanna or gianelle but they are not.
Old Sep 28, 2004 | 12:25 PM
speedform's Avatar
speedform
I believe they are a BMW specific wheel by Breyton. They're avail. throught Tirerack.
Old Sep 28, 2004 | 12:46 PM
BOZ23's Avatar
BOZ23
How critical is the bolt pattern. they only have bolt patterns of 5x120. would a rim with that bolt pattern fit on our Z? Just wondering because I love this rim!!
Old Sep 28, 2004 | 12:54 PM
tylerdurden's Avatar
tylerdurden
They will not fit. They fit BMW and some Jaguars.
Old Sep 28, 2004 | 01:27 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
you can always get an adapter made... but adapters will be a minimum of 20mm in size... I can make them...
what is the offset of them ill tell you if they will fit...
Old Sep 28, 2004 | 02:28 PM
BOZ23's Avatar
BOZ23
I don't know the offset. Breyton doesn't list them on their website.
Old Sep 28, 2004 | 03:03 PM
03Z33's Avatar
03Z33
Breyton Vision:
The come in 19x9 et+38/ 19x10 et+42 but are 5x120. H&R make some adapters off the shelve to fit different bolt patterns, but they do also space out the wheel a bit. If it is 20mm spacing then these could be used no problem. Rear wheel weighs ~32.5lbs as per Tire Rack website...
also come in 18x8.5 et+42 / 18x9.5 et+19 (27.5lbs/30lbs) but the 9.5 rear will be difficult to fit with a spacer due to the lower 19mm offset.
You may want to check out the SSR GT7 a similar looking wheel, not as much lip but still high quality light weight and perfect fittment for the Z. HTH
http://www.tirerack.com/upgrade_gara...3&autoModClar=
Old Sep 28, 2004 | 03:13 PM
BOZ23's Avatar
BOZ23
this is probably as close as I'm going to get by giovanna called genoa:
Old Sep 29, 2004 | 11:48 AM
Hazade's Avatar
Hazade
those giovanna's look sweet man
Old Sep 30, 2004 | 12:54 PM
racingdynamcs's Avatar
racingdynamcs
wheels are from Breyton...
giovanna ripped the design from Breyton
Old Sep 30, 2004 | 03:28 PM
BOZ23's Avatar
BOZ23
whether they are ripped from breyton or not, they still are the bomb! I guess they had to change up the design by adding the rivets.
Old Sep 30, 2004 | 08:41 PM
MY350Z.COM's Avatar
SEXY!
Rev_Night
Nov 7, 2020 06:00 PM
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
