No tire pressure monitors
Old Oct 7, 2004 | 07:45 AM
stevem's Avatar
stevem
Default No tire pressure monitors
Did a search and didn't find an answer to this question. If I install wheels WITHOUT the TPM's, will the low pressure warning light come on?
Old Oct 7, 2004 | 08:21 AM
2003z's Avatar
2003z
after about 30-40 minutes of driving, the light will come on on the dash. No buzzer though,.
Old Oct 7, 2004 | 08:50 AM
zh.guitar's Avatar
zh.guitar
Leave your mark!
When I had mine out for awhile the buzzer would go off at start up. The light goes on and stays on.
Old Oct 7, 2004 | 11:09 AM
ADMAN's Avatar
ADMAN
Only if all four are gone. And, even that is not entirely true. I ran the whole day (with my track-only rims on) and never had my light or buzzer come on. The gauge just had the usual (--) dashes. Rather odd...
Anyway, just move the sensors over to your new rims. Easy fix...
Old Oct 8, 2004 | 09:24 PM
synth19's Avatar
synth19
I no longer have my track wheels with TPS... light never came on with my new wheels WITHOUT the TPS.... really weird.
Old Oct 10, 2004 | 11:36 AM
Wedge's Avatar
Wedge
From what I have heard, if you remove the TPS modules, you will not get a warning light or buzzer. The reason is that a signal must be sent from the modules to the receiving unit and if they are not there, you will get no "low tire pressure" signal sent.
I don't know what will happen if you keep the monitors stored in your garage close to the car when you start it up.......
Old Oct 11, 2004 | 07:46 AM
ChinaClipper's Avatar
ChinaClipper
ANSWER: nothing!
Monitors have a battery switch that is activated when the wheels start rolling faster than about 25-30 mph. Normal TPMS system behavior is upon removal of TPSs from wheels, display just shows "-" dashes, and after 45 minutes or so of driving, the dash light comes on (which would ordinarily alert the driver that perhaps the onboard TPS has a low or failed integral TPS battery).
HTH
Old Oct 11, 2004 | 08:12 AM
R1Rider's Avatar
R1Rider
Nothing. Every now and then I get the light on the dash, but only after a fairly hard drive through the twisty's. It goes of after I stop and restart the car.
Old Oct 12, 2004 | 10:16 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
actually... now that I have no tire pressure sensors on your car... if it doesnt see the sensors it wont beep at all... it will just show dashes...
Old Oct 14, 2004 | 03:30 PM
Wedge's Avatar
Wedge
I have checked a lot of boards on this issue and the majority of the people agree with what ChinaClipper and others have stated.
I.E. No signals from the TPS wheel units will throw a low pressure light to tell you of a system malfunction after not seeing a signal for 45 minutes or so.
The head end of the TPS system is in the dash on the passenger side. Has anyone condidered simply unplugging the connector from the unit? Wouldn't this get rid of the annoying light.
On the other hand, is it possible that another system will also see this as a TPS failure and give a different sort of warning?
Just wondering.......
Old Oct 17, 2004 | 05:12 PM
Reaper700's Avatar
Reaper700
Same, took of stock wheels and put on Nismo's with no TPS and got no warnings, lights or buzzers. Just straight lines on the TPS screen.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
