MyNISMO.com Wheel Spacers... Finally
Old Nov 24, 2004 | 10:29 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
Originally posted by Yellow Stealth
Got the spacers and the Nismo bolts. They look great.
I just called a shop to have them installed, and they are quoting me 5 hours of labor (at $100/hour)!! Does that sound right?
we charge $315 at 78.15 an hour...
but its something we do a few times...
Old Nov 24, 2004 | 10:33 AM
Yellow Stealth's Avatar
Yellow Stealth
OK, so the quote is not that far off in terms of time. They say about 5 hours, and you are saying about 4. For some reason I thought it was a much smaller job.
Oh well, anything to make the car look fabulous. Thanks for the reply Jason.
Old Nov 24, 2004 | 10:41 AM
Jason@Performance
Performance Nissan
no problem...
it is a farily easy install...
Remove Wheel,
Remove Caliper,
Remove Rotor,
Tap out existing hub bolts (there is a notch in the dust shield that will let them come out easily)
Pull in new hub bolts, take a few washers and put them under a lug nut and tighten it down until it is firm...
Replace Rotor,
Replace Caliper
Torque down lug nuts on wheel.
After 100 miles torque them down again...
Old Mar 17, 2005 | 01:11 PM
sentry65's Avatar
sentry65
the burninator
why aren't these listed on the performance nissan site anymore? was there a problem/defect with them?
Old Mar 23, 2005 | 09:52 AM
sroks5's Avatar
sroks5
I have 19" rims w/ +31 in front and +37 in the rear. What size spacers do I need? How much will it cost?
Old Mar 23, 2005 | 01:22 PM
Road Warrior's Avatar
Road Warrior
i thought about this mod...but then when you figure in the labor for install you could put that towards new rims...unless you have a way to do it yourself
Obadabot
Jun 18, 2023 11:31 PM
Depravity
Oct 1, 2015 04:49 PM
