Cracked K&N Air Intake?
Old 03-01-2015, 03:22 PM
BlanQshot
BlanQshot's Avatar
Default Cracked K&N Air Intake?
I don't know what to say.. cause idk what I'm looking at.
But I'm sure this is not normal.
And I am just simply assuming its cracked.... Cause it was not like this before.
No, did not JUST bought the car. I've had this car for a bit now.
Old 03-01-2015, 03:57 PM
dkmura
General & DIY Moderator
dkmura's Avatar
Received 1,292 Likes on 896 Posts
If you're looking at the filter itself- the photo looks like the coating is peeling off the filter material. I don't see any "cracking"...
Old 03-01-2015, 04:08 PM
BlanQshot
BlanQshot's Avatar
Should I be replacing it soon.. Since it doesn't look normal.
Old 03-01-2015, 04:31 PM
n0smoke
n0smoke's Avatar
Money on it that it's not a K&N.
Looks like a cheap Spectre job- the coupler following suit. I'd swap it out for a quality filter regardless: K&N, AEM, etc.
Old 03-01-2015, 04:49 PM
dkmura
dkmura's Avatar
Agreed- the other thing to consider is that cheap filter doesn't provide any better performance than the OEM airbox. That location allows warm or hot air from the engine and radiator to flow back into the intake. I'd put the OEM airbox and the cartridge filter back in rather than replace that crap filter.
Old 03-01-2015, 05:14 PM
BlanQshot
BlanQshot's Avatar
Thanks guys. Helps a lot
Old 03-01-2015, 08:08 PM
n0smoke
n0smoke's Avatar
If you do decide to keep it you could replace the plastic MAF adapter with a nice billet aluminum one and a bellmouth/velocity stack filter adapter. I had a short ram on my Maxima that was dyno proven on cars without associated breathing mods.
http://www.ebay.com/itm/03-06-350Z-G35-Altima-V6-AIR-INTAKE-MAF-Filter-Adapter-billet-aluminum-/151053828349?pt=Motors_Car_Truck_Parts_Accessories&hash=item232b8280fd&vxp=mtr
Also replace the clamp(s) with the T-Bolt style. Nice touch, better quality, not that expensive. NAPA sells them.
Old 03-02-2015, 11:41 AM
cashmoney03
cashmoney03's Avatar
True k&n filter media is colored from the oil that's used on it. Not some coating that cracks and flakes of.
Old 03-02-2015, 01:55 PM
Don Nguyen
Vendor - Former Vendor
Don Nguyen's Avatar
That does not look like a K&N filter to me either. Typically the K&N filters that I have seen had rubber tops/bottoms.
-Don
Old 03-04-2015, 08:41 AM
BlanQshot
BlanQshot's Avatar
Thank you everyone for your input.
Is it safe to assume that I would have to replace the whole intake with the filter?
Or just replacing the filter with just the K&N would be fine?
Old 03-04-2015, 09:00 AM
Syner
Syner's Avatar
That is most definitely NOT a K&N filter.
Replace the filter only. You're actually losing because of heat soak with the current intake though.
Old 03-04-2015, 09:23 AM
BlanQshot
BlanQshot's Avatar
What do you mean by your second sentence exactly?
Old 03-04-2015, 09:28 AM
Syner
Syner's Avatar
I mean: If you care about performance, move your intake. You are sucking in hot air from the engine, negating the purpose of changing an intake in the first place.
Old 03-04-2015, 09:41 AM
BlanQshot
BlanQshot's Avatar
I'm assuming its the way its setup..?
This setup was given when I bought the car. I have NO EXPERIENCE with Air Intake so I wouldn't know what I would be doing besides just swapping the filter..
Last edited by BlanQshot; 03-04-2015 at 10:17 AM. Reason: removed F/I to Air Intake. Miscommunication.
Old 03-04-2015, 09:49 AM
Syner
Syner's Avatar
This setup was given when I bought the car. I have NO EXPERIENCE with F/I so I wouldn't know what I would be doing besides just swapping the filter..
Old 03-04-2015, 10:05 AM
BlanQshot
BlanQshot's Avatar
I'm being dead serious.
When I reread what you said it makes sense.. but please correct me if I'm wrong.
It seems like the way it's setup it takes the air around the engine (hence thats where the air intake filter is at) and pulls it towards the engine to give it air.
However since the air intake source is almost next to the engine it's practically intaking hot air from the engine bay and feeding it to the engine..
Is this basically what you mean?
If so, then my perspective would be to move the air intake somewhere else like the bottom of the front bumper.
Old 03-04-2015, 10:08 AM
Syner
Syner's Avatar
That is correct. However, you said FI. I thought you were NA?
Old 03-04-2015, 10:16 AM
BlanQshot
BlanQshot's Avatar
Ah...
Wrong terminology..... I was simply thinking it was referring to the air intake..
/enoughspoonfeeding
**that post is corrected by the time you read this reply.
Old 03-04-2015, 10:25 AM
Syner
Syner's Avatar
lol all good.
You need to replace your filter. If you care about performance, replace the intake as well (you won't gain anything over stock though). A new intake will come with all the tubing you need. It shouldn't take longer than a couple hours even if you have no experience.
350Z_Al
10-29-2020 07:44 PM
Gruppe-S
Body Interior
13
05-16-2016 10:42 PM
04-04-2016 07:52 AM
Twenty4
01-17-2016 01:20 PM
Quick Reply: Cracked K&N Air Intake?
