Sponsored by:
Sponsored by:
can i swap 08 manual trans internals into 03 case?
Old 04-19-2015, 01:05 PM
Ben O'Neill
Ben O'Neill's Avatar
Default can i swap 08 manual trans internals into 03 case?
so i a 03 350z with the 6 speed that grinds in 3rd and 5th. i also have a good trans from a 2008 that i dont think will work b/c the starter is in a different location as well as the crank sensor and the fact that it runs the internal slave v/s the external of the 03.
is there any way to make this work out? are the cases the same if i were to swap the internals from the 08 into the 03?
any help is appreciated. i have searched but didnt find any info on it
Old 04-19-2015, 05:31 PM
Conway_160
Conway_160's Avatar
sell the 08 and buy a CD009 or CD00A
Old 04-19-2015, 06:49 PM
Cmsgthokage
Cmsgthokage's Avatar
If you're in the Bay Area you should sell me the trans if it's in good condition.
Old 04-19-2015, 07:18 PM
terrasmak's Avatar
Received 2,296 Likes on 1,653 Posts
Don't know, but I know I would pull it apart and try. But that is just me
Old 04-19-2015, 07:53 PM
350Z/370Z Tech Moderator
MicVelo's Avatar
Received 3,263 Likes on 2,321 Posts
Short answer: YES, it can be done.
Long answer: You probably don't want to do it.
Here's the reason why.
I got tired and sweaty just reading it but it was an exercise in "gearheadism". And that's a compliment to derektm, OP of the post referenced.
Mic
Old 04-19-2015, 08:43 PM
CNunes_95
CNunes_95's Avatar
Doesn't seem like anything simple could be done to make an HR tranny compatible with a DE, since it's an entirely different motor. Would sell the 08 tranny and buy a CD009. I'm trying to do the same tranny swap in my 03 as it grinds at 3rd at high rpms. My 6MT in my 03 still works fine for now, but it'll eventually poop out over time. CD009 is the only permanent solution
Old 04-23-2015, 09:11 AM
samsniss350z
samsniss350z's Avatar
I'd go along with CNunes.
11-09-2020 10:27 AM
11-01-2015 05:25 PM
350z82
10-01-2015 06:25 PM
Quick Reply: can i swap 08 manual trans internals into 03 case?
