Sponsored by:
Sponsored by:
VQ35HR light throttle hesitation
Old 07-04-2015, 08:33 PM
GT-86
GT-86's Avatar
Default VQ35HR light throttle hesitation
Hey guys posting on behalf of a family friend.
Basically they have a 2007 350z with the VQ35HR engine with 50k which has developed a slight hesitation/miss on light throttle application when taking off and while going through the gears. If more throttle is applied you can not notice this slight hesitation and engine revs fine.
I have searched through the forum but havent had any luck on finding what the cause might be.
Any help would be much appreciated.
Old 07-04-2015, 10:20 PM
03s2kman
03s2kman's Avatar
You could try to clean the maf sensors and throttle bodies. Also replace the intake filters while your at it and reset the ECU.
Old 07-04-2015, 10:27 PM
GT-86
GT-86's Avatar
Throttle bodies are clean. Resetting the ECU may be next on the list.
Sometimes it quite noticeable especially if your in traffic and take off in 1st and around 1500-2000rpm it start jolting then disappears over 2000rpm.
Old 07-05-2015, 01:44 AM
CJs_Z33
CJs_Z33's Avatar
Sounds like a misfire. Has the owner checked the spark plugs? Are they using 91 octane? How does the car idle?
Old 07-05-2015, 03:22 PM
GT-86
GT-86's Avatar
Car idles fine and 98ron fuel is used.
They removed one of the spark plugs and checked the gap. Engine still has the factory Denso iridium spark plugs fitted which has 50,000 kms on them.
Old 07-05-2015, 04:25 PM
CNunes_95
CNunes_95's Avatar
Is the SES light on?
Old 07-05-2015, 04:57 PM
GT-86
GT-86's Avatar
No warning lights present.
Uriyo_
09-08-2021 08:46 AM
04-22-2021 09:42 PM
350z82
10-01-2015 06:25 PM
Detailed Image
Cleaning & Detailing
09-28-2015 03:03 AM
samansharif
09-25-2015 12:31 PM
Quick Reply: VQ35HR light throttle hesitation
