Sub woofer Alpine Type-R (stealth)
Old 02-10-2014, 01:34 PM
akocur92
akocur92's Avatar
Default Sub woofer Alpine Type-R (stealth)
I want to remove the stock subwoofer and put my enclosure inside of it. I'm assuming from recent thread i won't be able to fit a 1Ft (tall) 1Ft 2inch (length) inside the stock area. (can someone confirm this) would rip it out myself and check, just been very cold past few days and wondering if you guys already have the info.
Also, was wondering if i could grab the RCA cable from the stock amplifier and wire it to my new amp. (yes i know i would need to splice this wire)
Furthermore, if the type r 10inch cant fit in the enclosure inside the stock location, how reliable is it mounting the type r in the stock subwoofer spot?
Thanks in advance.
Old 02-10-2014, 01:57 PM
NismoDude
NismoDude's Avatar
won't even come close to being able to fit. I fit a sealed box for an 8" sub in there. The space is very odd shaped. You have to buy, or build custom to put a 10" in there. I'm not sure if anyone has put anything bigger in stock location, I think I just saw one of the vendors on this site offering a custom box and downfiring 13 though.
Search is your friend here.
Hit the "vendors" link up top, then scroll to the bottom to "wicked cas", and check out their stuff.
Old 02-10-2014, 03:03 PM
Spork
Spork's Avatar
You can't fit a typical box inside. You need a custom-fit box. If you go this route, be sure to match the required space for the subwoofer to be happy.
You can't just mount a sub where the stock BOSE was unless you completely seal the interior of the space. The BOSE sub is an "open air" sub and was designed to be used without an actual enclosure. You can, however, find open air subs to fit in the stock location. Don't expect them to sound amazing, though.
Old 03-15-2014, 09:08 PM
akocur92
akocur92's Avatar
Thanks for the info, I ended up going with 2 Type R under the strut bar in the back.
Here pic
Old 03-17-2014, 09:08 PM
DarkCreep
DarkCreep's Avatar
I love those enclosures.
Old 03-20-2014, 10:12 AM
Richiec64
Richiec64's Avatar
Just wanted to say that I put an alpine type-r in an enclosure inside the stock location and it doesn't sound bad and fits perfectly. However, If I didn't have a roadster I would've put it under the strut as well
Old 04-25-2014, 05:03 PM
ShaqZ
ShaqZ's Avatar
What are the dimensions in the stock Bose space? The only dimensions for a box that fits that I've found on the forums is 18"X12.5"x6.5". I believe one or both of the TW3 boxes will fit in there. Either doing one of these or custom fiberglass.
http://www.crutchfield.com/p_1369331...W3.html?tp=112
http://www.crutchfield.com/p_136110T...W3.html?tp=112
Old 04-26-2014, 05:01 AM
dcains
dcains's Avatar
Think about this carefully. If the smallest dimension of the box that's known to fit is 6.5". and both of the boxes you linked yo have their smallest dimension larger than 6.5", why do you think one of those would fit???
Old 04-27-2014, 10:05 PM
ShaqZ
ShaqZ's Avatar
Well I forgot to mention in my post that a Basslink is known to fit as well and its dimensions are 14 1/2"X13 3/8"X9 7/8" or 14 1/2"X9 1/2"X15 3/16" if mounted vertically or horizontally and that 6.5" depth box had plenty of room.
Old 04-27-2014, 10:23 PM
dcains
dcains's Avatar
Don't think so. I've spent a lot of time in that space, when I built the box in my car, and there's not "plenty of room" for a box 6.5" deep. In fact, it's quite a tight fit. The 14.5" width is OK, but the other dimensions are just too large. Post a pic of that Basslink installed. FYI, here's a pic of the 18 x 12.5 x 6.5" box installed:
If the dimension was larger front-to-back, you'd never get the trim panel/grill back on, and if the box was taller it wouldn't fit in the enclosure because the back of the space is much lower than the front. This is just about the largest regular-rectangular box that will fit. You could make a box with more volume, but the shape would have to be irregular.
Old 04-28-2014, 11:28 AM
ShaqZ
ShaqZ's Avatar
Plenty of pics in this thread. I'm surprised you hadn't seen it.
https://my350z.com/forum/audio-build...ory-space.html
Infinity site has the dimensions at 14-1/2" x 12-1/2" x 8". Crutchfield measurements were the ones I posted above.
Old 04-28-2014, 01:23 PM
dcains
dcains's Avatar
I hadn't seen that thread because that's not the sort of sub I was interested in. I'd double-check the actual dimensions before buying one.
Old 09-03-2014, 05:14 AM
thatoakboy92
thatoakboy92's Avatar
Here pic
Is this the Zenclosure box? If so how does it sound?
dcains
11-11-2015 11:36 PM
Ryan Bonner
350Z Roadster
09-08-2015 04:16 AM
Gish
12-26-2002 12:15 PM
TDOT350Z
07-23-2002 02:20 AM
Quick Reply: Sub woofer Alpine Type-R (stealth)
