Accessory power in trunk
Old 12-17-2015, 03:30 PM
ry4ndavis
ry4ndavis's Avatar
Default Accessory power in trunk
Anyone know of any accessory power in the trunk area I can tap into. I'm wiring up a rear view camera but want it on the whole time the key is turned on. The closest place I can think of is the rear cigarette lighter which I don't want to go all the way too. I have the touring so i know that bose has an amp in the back underneath the foam anyway I can tap into that? already got rid of all my blows (bose).
Old 12-17-2015, 04:46 PM
HRMoneyPit
HRMoneyPit's Avatar
Why would you want the camera on at all times is the bigger question
Old 12-17-2015, 05:08 PM
turboed350z
turboed350z's Avatar
because he removed the rear view mirror for weight reduction yo
HRMoneyPit (12-17-2015)
Old 12-18-2015, 08:15 AM
iideadeyeii
iideadeyeii's Avatar
If you have the factory bose amp back there you can tap into that.
Old 12-18-2015, 12:53 PM
JMII
JMII's Avatar
Only when the key is on.
I wonder if the power to the reverse lights is enough? Maybe if the bulbs were replaced with LEDs?
Old 12-18-2015, 02:10 PM
turboed350z
your reverse lights stays on while youre driving????
Old 12-18-2015, 03:22 PM
HRMoneyPit
HRMoneyPit's Avatar
Obviously while the key is on. Still doesn't make sense
Old 12-21-2015, 01:51 PM
JMII
JMII's Avatar
Wink
Yep... the entire time I am in reverse
Not sure why the OP wants the camera on ALL the time, maybe his review mirror broken?
Old 12-21-2015, 03:14 PM
ry4ndavis
ry4ndavis's Avatar
It wouldnt be on my HU all the time just power to the reverse camera would be all the time. ill have power to the actual camera all the time and I have the reverse signal wire from the back of head unit connected to rear signals so when I put in reverse HU will switch to camera but if i want i can manually select it and view the camera while driving. This is why i want power all the time. ha
jdmfetish
Suspension
21
02-29-2016 05:12 AM
ThatKidWithaZ
12-17-2015 01:19 PM
Timmy Tran
12-15-2015 03:51 PM
Bobby_Lee
12-13-2015 09:20 AM
Quick Reply: Accessory power in trunk
