My stock runs, so so conditions...slips inside.
on
I ran last night at the AID in Steele. The conditions weren't the best, as it was a hot day earlier, 87, and the humidity was very high.
The conditions during my best pass was around 72 degrees F, humidity around 87%. The track elevation is listed at 500'.
I should have been able to run a 13.8 on a few of the passes, but I was messing around with shift points, and shifted a bit early.
Excuses, my car felt like it was running worse than usual after a half a tank of BP 93 gas.
The timing lights eventually went out in the right lane for the 1/8, and the 1,000 ' has been out for some time.
My best pass was a 13.937, and most of them were 13.9's. My best m.p.h. was 100.97.
All in all I was satisfied, as the condtions weren't that great.
I am guessing that a run on a cool or cold day in October-November will get me down in the 13.5-13.6 area, with a trap of around 102. Speculation though, time will tell.
Here are the slips.
Oh yeah, to give you an idea of the conditions, there was a SS Camaro running around a 13.9@101, the fastest 99+ GT was ran a best of 14.611@95, and his was stock. He was still running better than a couple of GT guys with basic bolt ons. My friends brand new 04 Accord coupe 6 speed ran a best of 15.1@95, with bad launches. Could have run a 14.7 probably.
Here are the slips.
on
your atmospheric conditions equated to about 1500' DA. So when the weather gets to the mid to high 60's with less humidity you should be good for a couple tenths less. the weather you had is actually pretty decent for this time of year, it was like that here friday but i chewed up a synchro in the tranny. I keep a record of corrected times to see how my car responds to mods and different driving. right now i am looking for 12.8s when the weather gets better @ 104-5.
Turbo Whore
on
1 Post
That's pretty much exactly what I ran on a hot humid day last year. This spring with 60F temps and nice high pressure I ran the times and traps in my sig. Your car should be good for at 13.6@102-103mph.
on
I am hoping to run a 13.6 stock like you said, when its cooler.
I launch at around 2500-3000 rpms, feathering for traction. I let it out pretty fast though, as I want a quick launch, not a clutch slipper.
I will be running again in a couple of weeks, and I'll post my times then.
