Jim Wolf 350Z Clutch/FlyWheel Combo 07+ HR $760 Shipped
Old 05-19-2011, 10:18 PM
Mike@CZP
Concept Z Performance
Mike@CZP's Avatar
Default Jim Wolf 350Z Clutch/FlyWheel Combo 07+ HR $760 Shipped
Hey 350Z owners, we just got in these new Clutches and Flywheels for HR Engines. Fast 3-Day shipping to anywhere in the lower US for only $760.00 shipped for the Clutch/Flywheel Combo. Place your order and we ship it out the same day! Just click on "Add to Cart" to be directly linked to our website to easily place your order. Simply put "My350Z Quote" in the comments section and we will manually change your pricing. PM me for pricing to different countries.
Free Parts Include: Alignment Tool, Stainless Steel Braided Clutch Line
Brand New Nismo Pilot Needle Bushing : Free!
Only we provide the Alignment Tool in our combo.
JWT 350Z Clutch / Flywheel Combo w/ Bonus Free Parts, $760.00 Shipped!!
Or if you just want to order the clutch, we are selling them for $420.00 shipped!
JWT Heavy Duty Clutch 07+ HR Engine 350Z, $420.00 Shipped!!
JWT Replacment Flywheel Friction Plate Insert, $75.00 Shipped!!
Replace your Concentric Slave Cylinder w/ the lastest revision from Nissan.
Nissan OEM 350Z Concentric Slave Cylinder 07-08, $91.00
For Higher Torque Rating, we recommend the ZSP Heavy Duty Slave Cylinder.
ZSP 350Z Heavy Duty CSC Concentric Slave Cylinder 07-08 HR, $325.00
Description: After many months of testing and design we at Zspeed Performance have came up with an affordable aftermarket slave cylinder design for the HR and VHR cars.
We have now logged over 20,000 miles in multiple cars with 0 CSC failure even with heavy aftermarket clutches. The design work/product has been done for months but we felt it was something that needed to be tested in cars for many miles before just selling them to you guys, We wanted to make sure these are going to hold up for the long run. With our extensive testing we are now satisfied with the results and have decided to release them to the public.
Instead of modifying the Stock OEM plastic concentric slave cylinder that have known issues we decided to use a much better designed, heavier duty slave cylinder in our new kits.
The kits come complete with everything you need to install, No other parts are needed other than a couple jars of FRESH SEALED CONTAINERS of Dot 3/4 brake fluid.
It will be necessary to modify the front cover of the transmission slightly in order to fit the bigger, heavier duty slave cylinder into the transmission housing. This takes about 10 minutes and is pretty simple to do. All instructions are included with the kit or will be e-mailed to you in PDF format.
The ZSpeed heavy duty slave cylinder kit features all metal/aluminum construction, Floating internal seal (better than stationary that is used in the OEM Slave) All stainless fluid hoses that delete the stock rubber hose by your exhaust.
Though it is rare to see a warranty with after market performance parts we are so confident with this new slave kit that we are going to offer a warranty on the slave itself for 3 months from date of purchase when purchased and used with any Southbend DXD clutch kit purchased from ZSpeed Performance. Since we know these kits are made to the correct specs we are able to do this. Warranty only covers failure within the slave cylinder for defects, This will not cover slaves that were installed incorrectly, Lines that were not flushed out before install etc. Returned slaves will be inspected for debris and dirty fluid upon return. It is imperative that the install instructions are followed and lines flushed of old contaminated fluid to insure long slave life. Any failed slave cylinders will be replaced with new slaves one time only within the warranty period. No labor or any other fees will be refunded.
We have 2 different kits available to work with whichever clutch kit you may have, Stock, Aftermarket, flat finger or rounded finger designs. The ZSpeed slave kit will work with any aftermarket clutch with the exception of RPS/SZ kits, We have not been able to check this kits height as it uses an out dated 300zx pressure plate.
Mike@CZP is offline
Old 06-06-2011, 10:50 PM
Mike@CZP
Mike@CZP's Avatar
Bumped!!
Mike@CZP is offline
Old 06-21-2011, 05:29 PM
J123456
J123456's Avatar
does it come with throw out bearing?
J123456 is offline
Old 06-21-2011, 09:38 PM
Mike@CZP
Mike@CZP's Avatar
No, there is no throw out bearing made for these.
Mike@CZP is offline
Old 06-28-2011, 08:06 AM
Mike@CZP
Mike@CZP's Avatar
Bumped!!
Mike@CZP is offline
Old 06-30-2011, 01:25 AM
Mike@CZP
Mike@CZP's Avatar
Bumped!!
Mike@CZP is offline
Old 07-05-2011, 07:42 AM
Mike@CZP
Mike@CZP's Avatar
Bumped!!
Mike@CZP is offline
Old 07-11-2011, 12:14 AM
Mike@CZP
Mike@CZP's Avatar
Bumped!!
Mike@CZP is offline
Old 07-15-2011, 11:08 AM
Mike@CZP
Mike@CZP's Avatar
Bumped!!
Mike@CZP is offline
Old 07-19-2011, 12:51 AM
Mike@CZP
Mike@CZP's Avatar
Bumped!!
Mike@CZP is offline
Old 07-21-2011, 02:33 PM
Mike@CZP
Mike@CZP's Avatar
Bumped!!
Mike@CZP is offline
Old 07-26-2011, 12:37 AM
Mike@CZP
Mike@CZP's Avatar
Bumped!!
Mike@CZP is offline
Old 08-05-2011, 12:10 AM
Mike@CZP
Mike@CZP's Avatar
Bumped!!
Mike@CZP is offline
Old 08-07-2011, 04:56 PM
hostilityy
hostilityy's Avatar
what exactly is the concentric slave cylinder ? my oem slave cylinder has busted twice within 2k miles. i may buy this
hostilityy is offline
Old 08-15-2011, 12:02 AM
Mike@CZP
Mike@CZP's Avatar
PM Sent
Mike@CZP is offline
Old 08-19-2011, 12:27 AM
Mike@CZP
Mike@CZP's Avatar
Bumped!!
Mike@CZP is offline
Old 08-22-2011, 08:51 PM
ROCA Z
ROCA Z's Avatar
jwt clutch/flywheel combo, and HD CSC (aftermarket) shipped to 34108...
any special on the hd csc if but as a whole!! thank you !
Roca.
ROCA Z is offline
Old 08-22-2011, 10:44 PM
Mike@CZP
Mike@CZP's Avatar
PM Sent
Mike@CZP is offline
Old 08-29-2011, 12:52 AM
Mike@CZP
Mike@CZP's Avatar
Bumped!!
Mike@CZP is offline
Old 09-01-2011, 06:50 AM
gregory71687
gregory71687's Avatar
What kind of deals do y'all have for us vq35de guys?
gregory71687 is offline
Quick Reply: Jim Wolf 350Z Clutch/FlyWheel Combo 07+ HR $760 Shipped
