FS: OBX helical LSD, OEM 3.5 gears, poly-filled trans mount
Old 10-22-2013, 01:54 PM
bmyles
bmyles's Avatar
Default OBX helical LSD, OEM 3.5 gears, poly-filled trans mount
Unused OBX helical LSD. I replaced the shims inside with wave spring washers for correct preload and replaced the hex bolts that hold the case together. Comes with new axle stubs, bearings, ring gear bolts, axle bolts, and oil seals.
$550 shipped (Only use Goods/Services on Paypal, NO GIFTS)
LSD SOLD
TRANS MOUNT SOLD
GEARS SOLD
bmyles is offline
Old 10-25-2013, 08:29 AM
PercisionDriver
PercisionDriver's Avatar
Would you be willing to separate out the seals and bearings for the LSD? I only need to rebuild, so I don't need the axle stubs or LSD.
PercisionDriver is offline
Old 10-25-2013, 09:12 AM
bmyles
bmyles's Avatar
I'd like to keep it as a package deal at least for a little while because it's a good selling point. Might separate later on.
bmyles is offline
Old 11-01-2013, 12:49 PM
350ZZJoe
350ZZJoe's Avatar
If you do change your mind, I'd be interested in those axle stubs. Let me know.
350ZZJoe is offline
Old 11-02-2013, 05:57 AM
chriswagner92
chriswagner92's Avatar
Damn I wish I had enough for that LSD... If you still have it laying around in a few weeks let me know. Glws
chriswagner92 is offline
Old 11-09-2013, 09:57 AM
bishop_98
bishop_98's Avatar
Sent PM about the mount. Please contact me asap.
bishop_98 is offline
Old 11-09-2013, 01:33 PM
bmyles
bmyles's Avatar
Replied
bmyles is offline
Old 11-09-2013, 05:16 PM
bishop_98
bishop_98's Avatar
Payment sent for urethane trans mount.
Old 11-13-2013, 07:43 PM
myork
myork's Avatar
Is the OBX for the open diff, vlsd, or 5AT pumpkin case?
myork is offline
Old 11-13-2013, 08:39 PM
bmyles
bmyles's Avatar
Because it comes with axle stubs, it will work in open or VLSD. As far as working with an automatic, that shouldn't matter. Automatics just don't play nice with the steeper gear ratios, like 4.08s.
bmyles is offline
Old 11-15-2013, 04:44 PM
bishop_98
bishop_98's Avatar
In 15 min, I will properly mount a tranny.... it'll be awkward, but I've heard it's *really* tight....
Thanks for the Trans mount. I'll post my feedback.
Old 11-19-2013, 07:47 AM
bishop_98
bishop_98's Avatar
In all honesty, i dont feel a difference with the urethane trans mount. Granted, my rear diff is acting up and is all over the place so i have another diff and solid diff mounts waiting to go in, but all this talk of "60/75/90 trans mounts increases noise/vibration" is crazy talk to me.
.....just my .02
Old 11-27-2013, 01:24 PM
The_Assassin
The_Assassin's Avatar
If you don't mind me asking. Why aren't you installing it anymore?
The_Assassin is offline
Old 11-27-2013, 01:31 PM
bishop_98
bishop_98's Avatar
Was that directed at me? I did install it. I just dont feel/hear any difference at all... i mean.... nothing. Granted, i have factory engine mounts and rear diff bushings.
Old 11-28-2013, 09:02 AM
The_Assassin
No I was asking op why he didn't install the lsd
Old 11-28-2013, 08:41 PM
bmyles
bmyles's Avatar
Motor decided to die before I got around to it (low compression cyl 3). I was probably going to do it this winter or something if I still had the car. Pretty bummed I never got to try it out.
bmyles is offline
Old 11-29-2013, 12:19 AM
The_Assassin
yea i dont see any review or anything on here for it.
Old 11-30-2013, 12:02 AM
2007base350z
2007base350z's Avatar
Pm me plz
2007base350z is offline
Old 12-09-2013, 11:13 AM
bmyles
bmyles's Avatar
Bump
bmyles is offline
Old 12-09-2013, 02:29 PM
The_Assassin
If this doesnt get sold in a couple weeks its mine. Christmas gift spendings is taking away from my car money ….btw why did you change all those parts in it ?
Quick Reply: FS: OBX helical LSD, OEM 3.5 gears, poly-filled trans mount
