clutch pedal adjustment
Old 01-17-2010, 10:50 PM
Synjn
Synjn's Avatar
Default clutch pedal adjustment
How do I adjust the clutch pedal to at what point where it disengages?
Can anyone point me in the right direction?
Old 01-18-2010, 12:02 AM
sdZ33
sdZ33's Avatar
there is a thread on that.... Just use the search and it should come up... Also look up "dwolf clutch kit"
Old 01-18-2010, 12:16 AM
GHOST1207
GHOST1207's Avatar
Try this, took me 5 seconds to find it
https://my350z.com/forum/g35-g37/439...great-mod.html
Old 01-18-2010, 12:38 AM
Synjn
Synjn's Avatar
thanks guys
Old 10-29-2015, 06:28 PM
AbrasiveRaysive
AbrasiveRaysive's Avatar
Default Weird feeling after adjusting clutch
Sp I just did this adjustment and the clutch grabs a little lower than usual (which I'm happy about), but after the clutch catches and I let my foot off the pedal, the pedal will stay there for a second or two and then it will pop out the rest of the way (like half an inch or so) what could this be and is there any way to fix it? It's just annoying. Thanks in advance.
Old 10-29-2015, 06:30 PM
HRMoneyPit
HRMoneyPit's Avatar
You need a RJM pedal. They are known sale right now
Old 10-29-2015, 08:31 PM
mr. sparco
mr. sparco's Avatar
RJM pedal is what you need but it could also be that your clutch fluid is old and needs to be replaced asap and/or the master cylinder is going out.
Old 10-30-2015, 03:47 PM
AbrasiveRaysive
One more question, does lowering the clutch pedal hurt the clutch in any way? Like will it make it wear out faster?
Old 10-30-2015, 05:00 PM
mr. sparco
mr. sparco's Avatar
Contact RJM but IIRC its like "riding the clutch" if lowered too much when disengaged.
Old 10-30-2015, 06:21 PM
350Z/370Z Tech Moderator
MicVelo's Avatar
Received 3,255 Likes on 2,316 Posts
It definitely could - not likely if done correctly but possibility remains. I would tend to think that more harm comes to the clutch master - what I suspect could be causing the "slow clutch return" issue mentioned earlier in this thread.
When you adjust the stock pedal by turning the rod, you force the master cylinder's piston to "reach" further and it can come into contact with "unfamiliar territory" in the cylinder and can gall the piston. This can cause sticking, leakage and air entrapment, all leading to engage/disengage problems.
I have done the mod and experienced no such issues but I moved mine very conservatively. Maybe 3 turns or so IIRC.
The beauty of the aftermarket pedal is the multitude of adjustments that you can make to the PEDAL itself while leaving the master cylinder relatively untouched.
Old 03-22-2017, 10:54 AM
davidmrqz3
davidmrqz3's Avatar
Sorry I know this is kind of an old thread but I'm currently having this issue in my 350z, the clutch pedal has like a 1" dead spot at the top and after I pass this spot my clutch pedal fully engages now. I'm hoping its not the master cylinder because I replaced that last year so what do I need to do or buy in order to fix this ? Thanks !
Old 03-22-2017, 01:49 PM
travlee
Master
travlee's Avatar
Received 9,049 Likes on 6,515 Posts
you may need to adjust the clevis.
Old 03-23-2017, 05:26 AM
Heel Til I Die
Heel Til I Die's Avatar
Received 1,063 Likes on 751 Posts
Did you compare the push rod length on the old MC when you installed the new one to make sure the length was the same?
11-09-2020 10:27 AM
sherm
04-11-2020 05:21 PM
EnjukuRacing
09-30-2015 06:55 AM
Quick Reply: clutch pedal adjustment
