Can't read my engine oil dipstick
Old 09-23-2010, 11:01 AM
JDMStanced
JDMStanced's Avatar
Originally Posted by sanford
You get the car up to temp then shut it off for ten mins like it says in the manual.
Like i said in the first post, I cooled down before i checked the dip stick
Old 09-23-2010, 11:05 AM
JDMStanced
JDMStanced's Avatar
Originally Posted by Z1 Performance
the oil cap is only as hard to remove if you overtightened it the last time...it's not like it self seals
the dipstick is a bit of a PIA to remove on a DE (not impossible, just takes some finesse) but it's certainly not hard to read. If you can't read it properly, you probably shouldn't be taking it out in the first place
After i noticed that the oil cap is impossible to screw off by hands, I began to tighten it not as hard. BUt still IMPOSSSIIBLE lol
I can read properly if it shows properly One of the reasons why it's so hard to read might be because the new oil is so clean I've tried many different angles of lights to reflect the light on the oil but still hard to justify where it begins and ends
Old 09-23-2010, 11:58 AM
thekinn
thekinn's Avatar
I was eluding to the fact that you should do a quick search on the dipstick topic. That's what the was for.. But you seem to be taking your lumps in stride..
Wait longer after cool down to check your oil. Like hours. Or even overnight. You will have much greater success. (plus the new/clean oil is very difficult to see on the stick)
Good luck with the drip location. I had a faulty rubber gasket in my catch can that caused a leak.. but it was more than a drop or two.
Old 09-23-2010, 12:06 PM
JDMStanced
JDMStanced's Avatar
I lost the rubber ring in the catch can hahahahahah. So i cut a bigger ring to get the right size, then used silicon to glue that on. After i removed the catch can after oil change, it won't screw back in all the way because of silicon on the thread i might have to consider getting a Husky catch can
If air or oil leaks from the catch can, does it affect how the car runs?
Old 09-23-2010, 01:27 PM
djamps
djamps's Avatar
It's a pain, but both of your issues can be overcome with practice (and a gym membership haha)
Old 09-23-2010, 05:21 PM
Welcome to 2003.
Old 04-30-2016, 02:14 AM
350z_Lam
350z_Lam's Avatar
Is there another way to read the oil level besides checking the dipstick because every time I check my oil (after letting it sit for 10 min after warming up and wiping it down the first time of course) the whole entire stick is filled with oil still and I can't get an accurate reading. Am I doing something wrong?
Old 05-01-2016, 07:03 AM
terrasmak's Avatar
Received 2,284 Likes on 1,646 Posts
Wipe it, check again. You may have to pull it and wipe it 3-5 times to get an accurate reading
Old 05-01-2016, 07:57 AM
i8acobra
i8acobra's Avatar
Received 1,267 Likes on 1,015 Posts
Best way to check oil in a VQ35 is after it's been sitting over night. Before you start the car, pull out the dipstick. It should be easy to read then.
Old 05-01-2016, 10:56 AM
StuLax18
General & Tech Moderator
StuLax18's Avatar
Received 3,339 Likes on 2,379 Posts
Should be no need to wipe it after it's been sitting that long as it all should have settled I would think. Even if it's not perfectly clean, you should get a clear point where the oil level was.
Old 05-01-2016, 06:52 PM
dkmura
General & DIY Moderator
dkmura's Avatar
Received 1,292 Likes on 896 Posts
Here's a DIY thread from last year on this very topic:
https://my350z.com/forum/engine-driv...il-levels.html
lapham3
10-07-2022 03:15 PM
07-10-2022 07:44 AM
apex locator
07-23-2021 02:27 AM
Quick Reply: Can't read my engine oil dipstick
